French Import
zippy_gg's Avatar
Checking my work...
How deep does the shift rod seal should be inside the transmission housing?
It is for the 915 in my 86 cab.
I'd hate to put the engine/transmission back in the car only to find a leak.
Also, where can I find the 2 bullet nose connectors that plug onto the reverse switch? Mine came loose when I unplugged everything upon removal.
Thanks!
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 03-16-2016, 10:07 PM
ROW '78 911 Targa
timmy2's Avatar
No Brake lights
Reverse switch pin part number I posted recently.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 03-16-2016, 10:21 PM
French Import
zippy_gg's Avatar
Originally Posted by timmy2 View Post
No Brake lights
Thank you Dennis. Parts ordered from PP.
Gilles & Kathy
Old 03-17-2016, 10:37 AM
French Import
zippy_gg's Avatar
Can anyone help me with my first question?
How deep does the shift rod seal should go into the transmission housing?
Thank you!
Gilles & Kathy
Old 03-17-2016, 10:45 AM
Flush.
206 637 4071
Old 03-17-2016, 11:48 AM
French Import
zippy_gg's Avatar
Originally Posted by john walker's workshop View Post
Flush.
Thank you John. I am about 2.5 mm inside from the nose piece.
Should I remove and install a new seal?
Gilles & Kathy
Old 03-17-2016, 02:00 PM
French Import
zippy_gg's Avatar
Actually 3 mm deep...
Gilles & Kathy
Old 03-17-2016, 07:14 PM
That should not adversely affect the functionality of the seal.
'84 Carrera Targa (3.0 with SSIs, Webers, DC-19 Cams, MSD) - Sold
Old 03-18-2016, 10:18 AM
I think you may want to polish the shift fork shaft wherever it contacts that seal. If it is rusty and rough, it is going to leak. In fact, clean up the whole shaft and apply some lubrication before you put the fork into the housing. Any sharp edges will cut up the sealing surface of the seal as you slide the shaft into it.
Bob B
Old 03-18-2016, 10:44 AM
French Import
zippy_gg's Avatar
Bob B
The plan is to remove all burrs, rust, and imperfections before reassembling.
Good call on lubing the clutch fork; I didn't even think of that.
Gilles & Kathy
Old 03-18-2016, 03:37 PM
