Send a message via Skype™ to SorenDK
Sensor on Chain housing cover
Hello everybody - I just have a quick question. Im upgrading to carrera Chain tensioners but just realized the driver side chain cover is missing the hole for the temp. switch. Im wondering if this switch is necessary or can i delete this - if delete how should wiring be handled ? I have a 1977 with CIS.
Thanks a lot guys
Søren
My 69E project ...
http://www.youtube.com/user/ditster666
Old 03-20-2016, 09:34 AM
ROW '78 911 Targa
timmy2's Avatar
You sure there isn't a plug of some type where it should go?
Mine had one when I swapped over to the hydraulic tensioners.
Flip both over to look at the internal side and compare them.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 03-20-2016, 10:04 AM
al lkosmal's Avatar
the sensor on the drivers side chain cover is the thermo-time switch that provides 12VDC/activates the cold-start injector. if you are running CIS.....you need it .
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 03-20-2016, 11:07 AM
