Leakdown / Compression Question
Looking at a 68 912. Compression came back 172 across both banks. Leak Down was 29%
How bad is that leak down number? How does that compression number look?
Old 03-23-2016, 10:28 PM
Platinum Member
dad911's Avatar
Ugg. I cringe whenever I read about leakdown reports like that, because it isn't the whole story. Leakage of 29% is excessive, and mechanic should have told you what is leaking, intake, exhaust, or crankcase. Also, is it 29% across the board, or was that the worst cylinder?
If he is saying all cylinders are exactly 172/29% I'd say tend to think report is BS.
Old 03-23-2016, 10:36 PM
T77911S's Avatar
172, I would drive it and not be too concerned about the leak down.
I would think it would be hard to get 172 with a 29 leak down.
just my opinion, I don't or have not done a lot of leak down, just compression
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 03-24-2016, 04:36 AM
Platinum Member
dad911's Avatar
I took this to be a PPI not an existing car......
Old 03-24-2016, 05:28 AM
tharbert's Avatar
I think the important result is that the pressures are even across the cylinders, not the actual number. In any event, I'm no expert but doesn't 172 psi sound high?
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 03-24-2016, 07:33 AM
I don't think you can get 172 psi from a 912 engine. The compression rate is not that high. Secondly, if there is 27% leakage, it would be hard to get 172 psi from that cylinder.
The evidence is not complete but as it is right now, it points to a test performed incorrectly.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 03-24-2016, 09:12 AM
San Diego, CA
In my years of wrenching and instructing, I've used multiple brands of compression and leak down testers and run across more than a few bad testers. I'm always suspect of any tech's test results when a Harbor Freight tester is used. Yes, some "⎌Pros" use cheap tools.
Old 03-24-2016, 06:32 PM
