JWest Shifter Review
My 86 3.2 had the usual 'stir-the-pot and see what gear turns up' shifting issues.
Based on recommendations in this forum, I first changed all the bushings and installed a Wevo shift coupler which improved things quite a bit. I still had a little vagueness to the shifting occasionally and trouble getting into 1st and 2nd. So, I installed a factory short shifter thinking it might help out. It actually made things worse. First, the shorter shifter gave me less leverage to get into a tight 2nd gear--and second, the shifter knob kept pulling off in my hand while I was trying to shift. Also, it wasn't very easy to reassemble the shifter with the two big springs inside it. Today, I installed a JWest shifter with a 2 inch extension. It was easy. Very easy. It took me 15 minutes to get my console off and only about 5 minutes to install the shifter (the time it took to remove the housing bolts and bolt it back). I took it for a drive and it shifts smoothly. I think the primary difference is that its all brand new shiny components. They even provide all new bolts for it. The factory short shifter still used the old worn parts I already had which I think caused it to retain a little 'vagueness'. The two inch extension also gives me more leverage and brings the shifter back up a little closer to the steering wheel which I like. Anyway, I am very pleased with how the car shifts now and recommend it to anybody who was wondering about it.
1986 911 3.2 Cabriolet "We all have a desire to create something that will show we were here. " Ferry Porsche |
Thanks for the info. Can I ask what made your decision to go with the Rennshift from JWest over the Wevo shifter since you already had the Wevo coupling? I ask since I'm getting ready to the same upgrades and both companies products get high praise around here.
1981 911SC restomod "Minerva" 2004 Boxster S 2021 Cayman GTS 4.0 manual "Olive" 2014 Cayenne GTS V8 (wife's lover) The slope is not slippery; in fact it is entirely frictionless. |
I certainly can as I was originally going to go with the Wevo shifter just because it seems prevalent.
I had already wrestled with taking apart my shifter to install the factory short shifter and it isn't a fun process. The reviews on the Wevo indicated that I would just be installing their shifter in my house which sounds like using some of the same old parts and wrestling with the shifter housing again (it took me a day and a half to get it back together because of the high tension springs inside it). So, it was primarily the all brand new parts and preassembled housing that sold me on it. I can't speak for the Wevo, but the JWest is a breeze to install.
GOM (Grumpy Old Man)
I had a Rennshift (JWest) shifter in my SC and highly recommend that product. It is a complete self-contained plug and play unit with no mods or re-use of OEM parts required, which was appealing to me. Plus it is a great-looking product. Looked so nice I didn't even use the rubber boot that came with it. I also got the extended lever. Perfectly placed and closer to the steering wheel for easier reach. I bought their coupler (available as a package deal) and it was well worth it too. Likely similar in quality/performance to the Wevo coupler. JWest uses a Stomski coupler.
Thanks!
Hey Busta Rib, what color is your interior?
Since the title of the thread is JWest shifter review, I will offer my thoughts on the JWest G50 shifter kit. Installed it about 2 years ago in the 88 Carrera since I had developed the sloppy shifter syndrome. I love it. Short, crisp, and precise. For me it took more than 20 minutes to install. I'm using the stock coupler. Well worth the time and money.
gary 70T coupe forever almost done 88 Carrera Targa diamond blue |
wannabee wannabee
Another Rennshift happy customer here. I've enjoyed the last 2 years.. even now with bad 1st and 2nd gears. Looking to experiment 33% throw reduction once tranny gets sorted out (flame suit on!).
![]() Sent from my iPhone using Tapatalk
99 C4 - (let's try this once more) 07 Cayman S - sold 11/17 (not the same) 84 Carrera - sold 3/16 (geez what have I done!) Last edited by WIL84911; 11-12-2014 at 05:37 AM.. |
Good info. Leads me to some questions..
Does the JWest give a similar feel to the Sein Gate? By that I mean - can you feel the 1st/2nd plane vs the 3rd/4th plane? |
wannabee wannabee
The shifter rests on 3/4 plane. You have to slide left for 1/2 plane. Not sure if that answers your question.
99 C4 - (let's try this once more) 07 Cayman S - sold 11/17 (not the same) 84 Carrera - sold 3/16 (geez what have I done!) |
Slippery Slope Victim
I have had both the RennShifter in my track car and the Seine in my M491. The Seine is just fine and does the job. But the RennShifter is a precise piece of work and feels real nice and always positive.
MikeČ 1985 M491 |
Racer
I have the Rennshift in my race car and love it. I highly recommend the unit. I have mine set to the longest throw setting.
It is the stock red door panels that came with the car. The seats are Recaro LS that I bought in the aftermarket and they just happened to be a close match.
Yes, the gates are spring-loaded so the default is 3/4 and you need to give a slight push to the left for 1/2 and right for 5. Nice touch. |
I'm so torn on what to get, I have wevo mounts and psj and I'd buy undies if they sold them.
My wife's name is J West, So hard to decide. |
![]() Back to the topic, sounds like everyone likes the Rennshift. Searching tells me that Wevo users are also very happy, though installation requires re-use of stock parts. Has anyone here "converted" to the JWest from Wevo, or vice versa and can comment?
I have a Seine shifter, and am wondering your thoughts on the differences. I have always had a confident feeling with the Seine left side "gate tabs" that operate just like the 5th/reverse tab on the stock shifter. Does the Jwest unit do something similar and does it feel just as "mistake proof", in other words does it feel "gated"?
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa |
I Have a factory short shift kit and stomski coupler on my car. I have no other real comparison however as the only other 915 I drove was a OEM short shift too, but the gearbox was a mess. I will disclose that I ordered a Wevo shifter based on advice from a friend. Still waiting to get it in my hands, but I must admit that I probably did not research enough as I only reciently relaized that it was not an all in 1 unit like the rennshift. Given that it is more $$$ than the rennshift, it makes me wonder what makes it so good? Or, why is the rennshift more affordable? As far as reusable parts in the wevo, it would appear that the only part that is reused that is truly "wear and tear" is the plastic cup for the bottom of the leaver(edit, new bushings are included). On the plus side, I suppose that by reusing the original housing, the wevo unit stays closer to OEM.
1997 BMW M3 (race car) with S54 engine swap "The Rocket" 1984 Porsche 911 3.4 Carrera 1973 BMW 2002Tii 2016 Ford Focus RS Last edited by gliding_serpent; 11-29-2014 at 09:27 AM.. |
Installing the Seine kit is an upgrade to a STOCK shifter. Although it works fine, it is still a stock shifter. The tactile feel is different with the RennShifter, it is more positive and tighter feeling. It just feels and works better than stock. Also, the throw is adjustable.
Yes, to me it felt more gated for sure.
MikeČ 1985 M491 |
wannabee wannabee
Not sure if this can show how good it is but.... Let's go to the video (my son taping for me). Enjoy!!
https://www.youtube.com/watch?v=QDBJvV6VhAw
Just installed Rennshift. It is replacing a Seine shifter I've used for about three years. The Seine unit offers a lot of improvement and value for the money over stock. But the Rennshifter is in another league, shorter throw, much more precise, much "notchier". As others, I encountered no issues with the install which took about an hour all up.
jhtaylor santa barbara 74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's. 73 Targa (gone but not forgotten) Last edited by moneymanager; 11-28-2014 at 05:02 PM.. |
Thanks, Dave
Dave McKenzie 1984 Carrera 3.2 1984 928S Automatic 2001 996TT |
