rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
Door Handle Issues
Took my driver's door handle off because turning the key had no effect on the latch. Discovered that the screw behind the lock cylinder was loose. There's lots of black gook on the mechanism. I assume that I need to clean all of this off and put some blue Locktite on the loose screw. Do I need to grease the mechanism before reinstalling the handle. If so, what should I use and where should I put it?
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 04-14-2016, 11:36 AM
