Hub removal from trailing arm
Hi All!
I'm working on my 71 911T restoration. Now I am removing everything from the rear trailing arms. I have solved everything but the wheel hub. How do you get it out? Do you use a press from the backside? Or is there another way? Thanks for any input! Jörgen Forssling Göteborg SWEDEN |
Home of the Whopper
I used an old torsion bar as a drift and pounded it out.
1968 912 coupe 1971 911E Targa rustbucket 1972 914 1.7 1987 924S |
Bfh
Big slide hammer. BSH. Easier with the arm still mounted on the car.
non-whiner
I used a press as I had the arm off the car. The inner bearing race usually comes out with it.
"Too much is just enough." |
Rear hub removal.......
There are several methods people use for removing the rear hub/s successfully. Your choice would depend on the availability of the tool you like to use. With the trailing arm removed, a hydraulic press is best used. In situ, a big slide hammer, harmonic gear puller, BFH, etc. would be your choices. Take your time and be patient removing the rear hub. In my case, I have all sort of tools (press, slide hammer and puller, etc.) that I tried and used to remove the rear hubs in the past. After you have removed one, the next one would be much easier and less challenging.
Tony |
Thanks All!
The arm is off the car so I'll go to a friend with a press and work from there. //Jörgen |
Thread Tools | |
Rate This Thread | |
