What is this part? and where does it go?
Hi...
Have this part and wondering where it goes and what it's for?.... please help
Brent
Christchurch, New Zealand.
Project: 1973 RSR Clone build http://forums.pelicanparts.com/porsche-911-technical-forum/576125-nz-73-rsr-clone-build.html
Old 04-18-2016, 05:01 PM
ELZ's930's Avatar
Gas pedal rod support
Sent from my "Driving Shoe Phone"
the911den.com
Instagram / UberPorsche930
https://www.youtube.com/channel/UCg4ZbACRJsODXgnlMVZsjEg?view_as=subscriber
Old 04-18-2016, 05:02 PM
At the pedal end or the engine?
Brent
Old 04-18-2016, 05:25 PM
ELZ's930's Avatar
Looks like off the pedal board.
the911den.com
Old 04-18-2016, 05:27 PM
It's a support for a long hood door pocket.
Bruce
Old 04-18-2016, 05:45 PM
ELZ's930's Avatar
I think flat 6pac is right.
the911den.com
Old 04-18-2016, 05:46 PM
Bruce
This is absolutely correct^^.
It fits on the door near the front end of the long door pocket. The spring arm holds the pocket open when it's tilted open.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 04-18-2016, 05:52 PM
Sorry but I don't think so... that arm is no spring to hold a pocket up... it's of a reasonable size and would not fit on the end of door etc.
I'm thinking more along the lines to hold a cable... could be engine end?
Brent
Old 04-18-2016, 06:08 PM
Okay, I only owned 3 long hoods, so I guess you are right.
The spring doesn't hold the pocket up. The pocket has a nylon pin on the end that the spring holds with a bit of tension.
Do a Google search. https://www.lakewell.com/en/porsche/911/65-73/support-bracket-door-pockets-porsche-911-69-73
L.J.
Old 04-18-2016, 06:30 PM
My Apoligies!!!!!!!!!!!!!!
It is a "Left Door pocket support bracket" 90155508700 you were right and I was on a wild goose chase ... I won't be needing this anyway
Brent
Old 04-18-2016, 06:31 PM
No problem. Guess it would seem questionable if you didn't have a longhood with correct pockets.
L.J.
Old 04-18-2016, 07:29 PM
Have a long hood but it didn't have any interior pc's that I recall and I'm fitting RS door panels.
I wonder if this came with the 81SC I wrecked? anyway, will stick it on the shelf with other not required parts.
Brent
Old 04-18-2016, 08:33 PM
