I am moving fast and low, with a lot to get done in the next week or two, (making grilles too) http://www.x-faktory.com/store/p1/Custom_Grilles.html but I will measure and post my findings....as I have time. regards, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ Last edited by al lkosmal; 05-16-2016 at 08:11 AM.. |
Shiny bits
I had to take some time off for some well deserved R&R. Can you guess where I was?
![]() Well....I'm back and back to work on the 2.7....... Some nice, shiny bits were waiting for me. ![]() ![]() Just add E-cams, headers and sport muffler.....and go!! regards, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
Megasquirt
I love it when the postman stops by.........I just received the ECU from DIY Autotune. This time I am using the MegaSquirt-III EMS System with MS3X Expansion V3.57. Lots of cool features in this unit. I buy my Megasquirt units, per-assembled and tested, from DIY Autotune. They know their stuff.
![]() regards, al
I can guess Al...mmm let me see, just a wild guess...Hawaii???
Looking good |
Registered Minimalist
St. Thomas?
Engine is looking great. I want to do this to my 75 motor. I should clarify, I want YOU to do this to my 75 motor lol.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
Hanalei Bay
Winner! Winner!
Winner! Winner!.............The Hanalei Canoe club was out practicing as the sun went down on the bay.
regards, al
tool
i'm always updating my Porsche tools....and this is my latest.....the Stomski Racing Circlip Injector Tool........these circlips are a beeeeyatch to install and the ones that come with JE pistons are especially tough....but this tool worked great...........I recommend it highly......
![]() ![]() ![]() regards, al PS: available on Pelican
testing testing testing
Well, i have been very busy and therefore neglecting the updates....so we will just have to fast forward to the testing phase.........I still have to route and trim the spark plug cables, plumb the fuel lines, wire up the TPS, etc.... stay tuned.
So in love with your ITBs Al. Just wished you lived in Adelaide...
Monitoring closely whilst on holiday in Fiji. BULA!! |
I'm using TWM/Borla ITBs on this build. Still a few details to sort out, including getting the MS3S prepped, but I should have this up and running next week. 1st fire video coming shortly. ![]() Bula, al
Hi Al
Always love to see your posts, you do great work. I have a 2.7RS ish engine with home made manifolds using the Triumph Tripple T-Bodies and just about ready for a first start. I am using Megasquirt 2 with direct ignition wasted spark, and would like to ask if you have base map "ignition and Fuel" you could share. Thanks Mike |
It is alive................
I mounted the engine on my test stand and completed the wiring/plumbing for testing, configured the MS3 for this engine (fuel requirements, etc.), loaded one of my start up files................and .........it is alive!!!!!!! I removed the fuel pump and injector fuses and cranked to build up oil pressure...................than replaced all that and it popped a few times and fired up/stumbled a bit..........I knew it was going to go, so I ran and got my camera. This engine still requires a day or two of fine tuning, ITB balancing, etc.....but it never ceases to amaze me when they just start up and run this well.
this video captures the first real start-up and run. https://www.youtube.com/watch?v=finbWiaFuPo regards, al PS: I used MS3 with the expansion board (pre-assembled/tested from DIY Autotune) The combo of Megasquirt and TunerStudio makes for a very feature rich, easy to use system.
Vintage Motorsport
Very nice.
btw - What's the bike hanging on the wall? I ride an old Bianchi ![]() Richard Newton |
Banned but not out, yet..
You are a wizard. Well done sir.
An air cooled refrigerator. ‘Mein Teil’ |
Never had carbs start "cold" that well. Tweak, tweak, tweak!
Thanks for sharing, Al!
R Gruppe #111 Early S Registry #235 res ipsa loquitur |
regards, al
regards, al
Thanks rick........this engine is headed for a 914/6.............
regards, al
Thread Tools | |
Rate This Thread | |
