Dreaded Broken Head Stud...
Was getting ready to clean up the SC and was changing oil, brakes, adjusting valves as car hasn't been driven much since 1998. (Less than 5k miles since Paul Wier Rebuild). Took valve covers of only to find a large hardened washer...then a short piece of Dilavar stud.
When Paul did this (rest his soul) he asked me about the Dilavar studs. He mentioned they can be problematic. I asked him Porsches recommendation and they were still pushing Dilavar. He wanted to use steel. I insisted Dilavar..... my bad. So now its out, and I decided to replace all the studs. Also had a 9% leak down in #5 all the rest were 3-4%. Sent the heads to Mark at Exotech and all new guides/seals etc. Only #5 was sticking a bit. But with it this far apart no sense sending in a single head. So now all the parts are back, exhaust ceramic coated, engine tin powder painted, crossmember, engine mount. All new injector bushings, orings, hoses, oil lines etc. Found a section in Waynes book about oil line restrictors, decided to order them...still waiting. With everything new up top and less that 5k on the bottom, anything else worth doing while its this far? It got JE Pistons, new oil pump, tensioner update, Mahle cylinders. All new bearings, rod bolts. New chains and gears, chain guides. ![]()
Reiver
Looks nice and clean.
How long/miles did that rebuild with the dilivar last you?
De Oppresso Liber Strength and Honor 5th Legion |
Still here
Reiver
If the dilivar was compromised then the engine sweat would attack the area. Shame.
Was the stud one of the latest type of fully threaded Porsche Studs?
I have to say that from a metallurgical perspective there is no logic to the concept that engines that are rarely driven should have more problems with a Dilavar stud. Dilavar is not an alloy which would corrode in the presence of condensed water as it is fundamentally an Austenitic Stainless Steel. The corrosion of grain boundaries in the presence of chlorides is the only issue that is likely to be a problem and cars that are not driven on salty roads are unlikely to be affected. There are also the reported failures due to hydrogen embrittlement which can only occur due to bad manufacturing practices. This type of failure will probably be stochastic in nature and very difficult to predict on an individual basis I still believe that there are studs being sold as Dilavar and these should be avoided like the plague. The 'Magnetic' Dilavar studs being offered being as case in point as the metallurgy of these studs is at best confused. I just bought new steel studs form Porsch and paid $6.50 each which is a great price. Last edited by chris_seven; 05-07-2016 at 12:33 AM.. |
Where did you send your exhaust to have it coated? What type of ceramic coating is that?
Something mystical to cleaned parts. Looking good Awjens ~
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
When you install the rocker shafts torque them to 21 ft lbs. This will keep them from leaking and they'll never back out. Also steel studs are fine unless you plan on building a high compression racing engine then I would use ARP. |
are you installing the cam oil seals?. Cheap insurance to insure against cam tower leaks.
1979 SC 1986 Carrera 3.6 L+ |
Component Coating 2550 California Ave Saginaw MI 48610 (989) 746-0891 |
Sherwood |
Reiver
I believe your explanation but I've heard this from numerous wrenches about the low mileage head stud issue. One, who I know well (been doing 911's since the late 70's) says he finds many more low mileage Dilivar issues than high. Obviously not the sweating issue but must be some correlation.
Because the bad one break early. The good ones last.
I didn't drive it often, but the office was 45 miles each way. Trips were 45 miles minimum. A few to the cabin and back >120 miles each way. It was never used for local driving or a trip to the store. Had I taken Paul's suggestion, I wouldn't be in here now. It ran great. These were factory Porsche Parts. I ordered them.i don't know why it would fail, but it does seem that a lot of them break on cares that are rarely driven.
Reiver
That is a possibility but you'd have universal statistics if that were the case.
Every P site I've visited that discussed this subject noted the same occurrence....more studs breaking on garage queens than high mileage cars. It would be interesting to find out why.
Hey Art, Glad you're happy with the heads. A favor though?
Been a week and a half but the money hasn't shown up in my Paypal?
Mark www.exotechpower.com 1981 Targa-messed with. 91 C2 supercharged track rat Radical Prosport-irritates the GT3 guys 40 years of rebuilding services |
