'73 911 T Targa
Allen wrench for spark plug tool
I want to get an Allen wrench for the spark plug tool that came with my '73. (See attached pic). My wrench doesn't appear to be terribly worn, but a 10mm hex is a sloppy fit. I tried an 11mm but it won't go in. Was this wrench a proprietary size?
Old 05-09-2016, 05:00 AM
Member 911 Anonymous
DRACO A5OG's Avatar
I can not imagine PAG would change from your year to mine but my allen key ( aka angular screw driver ) is 10MM, confirmed with my caliper.
Use some tape to fill in the gap?
'85 Carrera Targa
PCA/POC
Old 05-09-2016, 07:37 AM
I've noticed that many modern tools are not built to the exacting standard we would expect. Try a few different brands of allen. I recommend going on amazon and buying a Stahlwille, Hazet or Gedore allen wrench and using that as the basis for your search.
Old 05-09-2016, 10:27 AM
im also confident its 10mm, and i use either an allen key or a 3/8 ratchet allen key bit. I love the porsche spark plug tool nice it came free =)
Old 05-09-2016, 12:41 PM
KTL KTL is online now
Schleprock
KTL's Avatar
You're sure the receiving hole in the spark plug tool is a hex shape? Reason I say that is because some of the original tool roll spark plug sockets that i've seen have a 12 point triple square
Kevin L
'86 Carrera "Larry"
Old 05-09-2016, 01:34 PM
