'73 911 T Targa
Allen wrench for spark plug tool
I want to get an Allen wrench for the spark plug tool that came with my '73. (See attached pic). My wrench doesn't appear to be terribly worn, but a 10mm hex is a sloppy fit. I tried an 11mm but it won't go in. Was this wrench a proprietary size?
Member 911 Anonymous
I can not imagine PAG would change from your year to mine but my allen key ( aka angular screw driver ) is 10MM, confirmed with my caliper.
Use some tape to fill in the gap?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 05-09-2016 at 07:40 AM.. |
I've noticed that many modern tools are not built to the exacting standard we would expect. Try a few different brands of allen. I recommend going on amazon and buying a Stahlwille, Hazet or Gedore allen wrench and using that as the basis for your search.
im also confident its 10mm, and i use either an allen key or a 3/8 ratchet allen key bit. I love the porsche spark plug tool nice it came free =)
Schleprock
You're sure the receiving hole in the spark plug tool is a hex shape? Reason I say that is because some of the original tool roll spark plug sockets that i've seen have a 12 point triple square
Kevin L '86 Carrera "Larry" |
