Black and Blue
Leatherique Leather Dye - test results
All,
I have been working on the interior of my 81' SC project and decided to buy some better leather rear seats and door cards. Mine were cracked and dry, the door cards had some aftermarket tweeters screwed asymmetrically into the leather. With a mix match of parts, I figured the leather would have to be dyed for it all to look right. So I got my box from Leatherique yesterday and used one of the throw-away rear seats as a test subject. And not just any test subject, I wanted to do a hack job on the seat to see how the Leatherique would respond and also to get a feel for the new Harbour Freight airbrush from Central Pnumatic. All I did was use the prepping agent to Wet Sand with 400 grit, dried everything off with a blue shop towel and sprayed the leather with uncut dye. Then I hit it gently with the heat gun to set things up. Basically, I didn't follow the directions at all. and might I say... I am very impressed with the tentative results. these pictures were taken 5 min after spraying. The whole excercise took about 15 minutes, and thats with the clean up. On Friday, I will perform some resiliency testing to see how tough this outer layer is. I can only imagine how good it would have looked if I had taken my time to do the proper leather prepping. I was more concerned about trying out the Airbrush. ![]() ![]()
Kemo 1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore 1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver |
May I ask what color you ordered? My seats are exactly the color that your newly sprayed seats are, and I want to refresh them.
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa |
It is not going to stand up to anything harsher than water. Try wiping it down with denatured alcohol and see how much of it wipes off in your hand.
You would have to be careful how you clean it from now on.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Black and Blue
uwanna, if im not mistaken...its the Champagne II #925. But you can send in a sample to match if you like. I just ordered mine since I was doing all parts of the interior.
Porsche | Leatherique Restoration Products yelcab1, ill be trying all kinds of things...starting with the Leatherique cleaner which i have a lifetime supply of it seems.
Funny as F***! From the pics the finish looks good Kemo. Given Yel's input... very wary about using this stuff if water is only cleaner it stands up to.
Nice testing
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
San Diego, CA
Please explain. I have dyed countless interiors and not had this problem. I understand being aware and careful when cleaning a dyed seat, however, I have used cleaners much stronger than water. |
Now in Florida !
Location: York Beach, Maine and Anastasia Island, Florida
Does anyone here have a long-term report on the Leatherique, or any other leather dye?
1983 911SC Coupe Hot Rod - Platinum - Twin plugged 3.4, DC-60 cams, PMO 50's, 1 3/4 headers, Bill Rader 915 w/LSD 1976 914 2.0 Lime Green Metallic - Completely stock |
I did my cork interior many years ago with Leatherique and it has held up very well and I've cleaned it with Griot's garage interior cleaner regularly.
Rutager West 1977 911S Targa Chocolate Brown |
Administrator
Griot's is a good cleaner to use as it's not harsh and safely cleans interior pieces. That's good to hear it hasn't done any harm to your leatherique. Griot's does state:
![]() Griot's Garage Car Care Products - Pelican Parts |
I've used Color Plus which is the same compound that you are using for over 20 years. I know with their stuff you can only use water for 30 days to clean it. After that you can use the cleaner of choice and conditioner. I ended up being a installer for them for a while and the end result is extremely resilient. Only way to screw it up is to lay it incorrectly and creating a blemish. Trying to take it off once it sets up is a feat. You aren't going to hurt it. (Anything is possible but I am talking within reason here) I would also avoid application with a brush or cheese cloth. It does not give the same look as spraying it with a jam gun or air brush.
Stephen 94 3.6Turbo 6-speed AWD |
San Diego, CA
Perhaps yelcab1 was referring to the older lacquer based dyes. Those could wipe off and smear with one wipe of a harsh cleaner.
Leatherique dye system has been used for decades in ultra high dollar restorations for years, and those folks don't use stuff that doesn't work! In fact it was developed for the restoration business many years ago. ColorPlus is another maker of virtually the same product. Many Pelicans have used both over the years with excellent results, provided
it is applied correctly.
It was five or six years ago since I redyed the 328 interior with the Leatherique set up. I think it was water based as I used water to dilute it for the air brush. It looks very good because I used an air brush on it. It is almost of correct color, uniform in consistency, and looks much better than the beat up stuff that was there before.
I cleaned it with water, soap and water, leather cleaner soap (Lexol), and it will be OK with that. But, If I use a towel with denatured alcohol on it, the color will rub off on the towel. So I stopped doing that. I have used denatured alcohol to clean stuff off leather before without rubbing off the dye, but it was factory dyed seats. Leatherique is fine to use, just stay away from the very harsh cleaners.
The biggest issue is not scuffing up the leather and prepping the surface so it's clean. Like anything the prep work and adhesion is key here. The alcohol shouldn't really cause an issue. I remember we had a customer that was having a hard time getting it off with thinner. Which by the way is the worst thing to ever put on leather!
If done correctly you would be hard pressed to tell its been done. I even changed the color of my couch once with it. It help up with 2 cats and 2 kids!
Correction, I just checked the can in my garage and the product I used was Colorplus and the date on the can was 2002, so 14 years and it has held up very well. I did use a brush and I think that it went on a bit heavy and gave it more of a plastic look, spraying is probably the best route.
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Connolly
I've used Connolly for years.
Also a very good product. Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
