SC injector and sleeve replacement
81 911 sc... can the air tubes ( manifolds ) be removed from the air box for sleeve and injector removal while leaving the CIS in the car my sleeves are brittle and pieces coming off the top so the injector will not clip and secure back in place
Old 05-28-2016, 01:51 PM
ROW '78 911 Targa
timmy2's Avatar
Not really, maybe the drivers side if you take almost everything else off. Better off to drop the engine either partially or fully, and remove the entire system.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 05-28-2016, 02:22 PM
Pete
I just did this. The issue is that some of the short rubber hoses have their clamp screws facing forward and you can't get to them without air box coming out. I did this with the engine in. It was not too bad. I started with the right forward most runner. It's the hardest to get to but with a 12mm socket and a 1/4" drive it's accessible but blind. I also used wobble extensions and an open end wrench in places.
So while your there, plenty of other things to replace too. ��
Pete
__________________________
'78 Arrow Blue 911SC
Old 05-28-2016, 04:13 PM
Yes, I 've done it many times.
Paul
Old 05-28-2016, 05:42 PM
thanks for the confidence building I can do this any tricks on how to make this an easy swap out
Old 05-30-2016, 08:08 PM
Injector removal is fairly easy. Sleeve removal is more complicated. Even if you get the air tubes off, you still have to deal with the possibility of pieces of the sleeve breaking off and dropping into the engine. I took my engine out, then it's easy to take the entire CIS off in one piece and replace the sleeves
Old 06-02-2016, 01:00 PM
Steve F's Avatar
Speaking of this, I am also doing the same thing, but with CIS on my bench. I turned a steel shaft to fit in the insulator from the bottom with a shoulder on it. I see the 3 punches at the top , and will replace all parts so don't need to save them. Can I just tap away on said tool and drive them out, or do I need to disturb the 3 punches first, if so how?
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate
1967 912-1985 Toyota FJ60 Landcrusier
1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4
1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag
1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS
Old 06-02-2016, 01:22 PM
Mark Salvetti's Avatar
I think you need to carefully grind those three detents off with a Dremel. I suppose you could try to bash the old sleeve past them when removing, but you'll still have to grind them off so you don't damage the new sleeves during installation.
Mark
1979 911SC Targa
Old 06-02-2016, 06:44 PM
Steve F's Avatar
Thank you, I can do that and a clicker center punch to re-install.
Old 06-03-2016, 05:35 AM
theiceman's Avatar
yes this can all be done with CIS in the car. its a nice after noon job .
1. pop the injectors out
2. with a dremmel and a vacuum grind of the detents.
3. pull out sleeves and o rings ( I think i used a big easy out to grab them and they popped right out )
4. reinstall new sleeves and orings.
5. use small chisel or flat blade and hammer to "peen " a couple spots to keep new sleeves in place.
6. install injectors with new orings.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 06-03-2016, 06:47 AM
