Accelerator Pedal Bracket Broken Repo?
So I started to work on a 67 911 I bought a few days ago. It had been sitting a while so I cleaned up the carbs some, rerouted the gas line to a gas can and it fired up pretty quick but it quickly rev'ed to 3000 so I shut it down. After looking things over I could see the throttle linkage was holding open the throttles. I followed it back to the gas pedal and I could see the bracket pictured was bent to the side and the linkage was stuck under a hole in the floor. Is this bracket reproduced? Is this a common occurrence? Thanks
Old 06-23-2016, 07:10 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Straighten and weld it up
'85 Carrera Targa
PCA/POC
Old 06-23-2016, 10:18 PM
right....should be an easy repair by welding.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 06-23-2016, 10:42 PM
tshebib's Avatar
Our host sells them
Part #: 901-423-250-02-OEM
Old 06-24-2016, 04:55 AM
Thanks for the replys. I did look for it here but I didn't find it. I'll look up the number you posted. I wish I still had my little welder but I hardly ever used it so I sold it.
Old 06-24-2016, 06:29 AM
tshebib's Avatar
Here you go
Porsche 911 (1965-1973) - Cables & Controls - Page 1
I bought a new one and then had my buddy weld up the old one as a spare.
There is actually more weld around that area on the new one than was on the original one.
Old 06-24-2016, 06:34 AM
tshebib's Avatar
New one is on the right
Old 06-24-2016, 06:39 AM
Cost me $20 to get it welded up, working good now.
Old 06-26-2016, 10:19 AM
steely's Avatar
awesome!
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 06-26-2016, 11:49 AM
DRACO A5OG's Avatar
Cool
'85 Carrera Targa
PCA/POC
Old 06-26-2016, 01:59 PM
Andy Bullen
andybullen's Avatar
Send a message via AIM to andybullen Send a message via Skype™ to andybullen
This is perfect timing.... My accelerator lever (901-423-250-02) has a lot of left/right play (enough that it sticks under the tunnel when depressed) and it has bronze bushings in place. Going to pull it out, I suspect it could look similar to your original picture.
76 912E - Grocery Getter
04 Toyota TacomaTRD - Beater Truck
08 Honda OdysseyEXL - Family Hauler
Old 07-27-2016, 10:08 AM
