What year car did these calipers come from?
As the title says. Looks like I have early suspension but later calipers. Any idea what year car they are from?
I want to rebuild them but not sure of what parts to buy. ![]() ![]()
What me speed? |
They look like front carrera calipers because of the spacer.
RETIRED
Ask Eric at www.pmbperformance.com or Bill Verburg.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
gearhead
Isn't there a date on the casting?
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Yuppo.
Don't see a date... But here is another pic. Thanks for the responses.
What me speed? |
gearhead
I thought I had seen Bill post at one point about dates calipers. I didn't find it with a quick search, but here's his reference sheet with measurements. This will let you figure it out for sure:
Brakes
if the spacer between the 1/2s is 7mm they are off a '76 thru '83SC or Carrera w/ a 20mm rotor if the spacer is 11.3mm they are off of a '84 thru 89 Carrera, still have the same 48mm pistons but the rotor is 24mm thick
They look identical to my 1984 Carrera calipers.
But listen to Bill, he is the total master when it comes to this stuff!
Christopher Mahalick 1984 911 Targa, 1974 Lotus Europa TCS 2001 BMW 530i(5spd!), Ducati 900 SS/SP 2006 Kawasaki Ninja 250, 2015 Yamaha R3 1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750 |
Ok. Looks like the spacers front and rear calipers are 11.3mm wide. Thank you for the responses. I can now order rebuild parts.
Now my next question.... The front suspension is looking like it was for a SWB car. My car is a 1971 911E. Yes this car is full of surprises. Can the later control arms bolt up to the older steering rack and crossmember? Would I get any benefit from trying to source a complete front suspension from a later car or is the SWB sufficient?
What me speed? |
