Member 911 Anonymous
Hella Fellas,
So, I was wondering what is the part or part number for the piece that goes between the two rear tins for a 3.2? ![]() The gap between tins 15 & 18 ( 911S but pictured for reference ) TIA ![]() Jim
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Platinum Member
I think they connect together, no gap in between:
![]() ![]() I am talking about that middle piece, it appears to be a rubber piece/part.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 07-09-2016 at 10:36 PM.. |
is it near the tdc sensor?
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
If you look at the second picture, the red arrow goes across it for the oil Pressure Sensor.
Brother Jim... looking at '79-930 tin set up. (Is not in final position due to engine mount.)
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
Hmmmm, from what I can tell, that red arrow (pointing to the oil pressure sensor) in the second picture is going across the TDC sensor 911-606-108-00 (NLA).
Whether the TDC sensor is sitting in a separate carrier, or that whole thing is the TDCS I can't tell - from looking at images of the sensor itself. Or am I way off? On edit, the TDC sensor sits in a bracket 930 101 191 02
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue Last edited by steely; 07-10-2016 at 06:23 AM.. |
Doh.
Ding Ding Ding, Winner Winner Chicken Dinner. STEELY hit it right on the head! I just remembered I had Tony Calas at Calas Rennsport do a TDC sensor delete as it was no longer used. I did not realize that meant removal of the rubber block, Oh well, now I know. I think I will make something up to block it up from a piece of rubber. Thanks again Brothers!
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 07-10-2016 at 10:22 AM.. |
oh cool, how about that, I'd heard it was just as useful as an appendix. An NLA you won't have to worry about.
