Why URO DME Relays Fail Right Out of th Box
I bought a URO relay because it was 1/3 the price of the others and I thought how can you screw up a relay? None the less I decided to test it and it didn't work.
The two center 4mm pins were very loose and freely rotated. They look to be silver plated but tarnished. I screwed with it and it started to work. The swaged pins are not tight to the metal jumper strips that go to the PCB. I decided to fix it by hitting the top of the pins with a punch (see the center bottom pin in the lower photo). Getting the bottom off is not an easy task btw. I hope the profile of the pin has an area to accommodate the plastic of the base and the swaging doesn't also compress the plastic. I'm thinking of adding solder if the plastic will take it. ![]()
Rick 88 Cab |
Junk. Use the Kaehler brand. KAE. German.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 07-13-2016 at 09:37 AM.. |
That was my first thought but I like to do failure analysis.
EDIT: this is a spare. The original had a bad solder joint.
Rick 88 Cab |
Member 911 Anonymous
Well, now we know how to fix them on the fly.
Thanks brother Rick! Hey URO guy, you watching this, I think you should send this to China to let them know what they need to do. a Super simple fix or manufacturing step. For them maybe .5 cents in cost per week?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
RETIRED
URO products aren't worth being a door stop.....why bother?
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
I'd solder it and be done with it. It'll work fine because the silver-platted stuff wets easily by the solder. And if the plastic gets hot and deforms a little - who cares..... While you are at it also reflow the other solder joints as they look a little thin.
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
Apparently the swaged top of the pin also compresses the plastic because the pins got loose again after the heat of soldering.
This thing is a piece of junk but if you want to resurrect one I think you could get in and solder the tops of the pins without removing the PCB.
Rick 88 Cab |
Is there a country of origin on that part? It looks like the crappy is built in
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car 77 BMW R100S 99 Ducati 996S 04 BMW R1150R DanielJacobsLLC.com |
Most URO parts suck, they have the same bad rap when it comes to Saabs.
72 911 Although it is done at the moment, it will never be finished. |
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Lots of their crap comes from China but not all of it. JR |
I do not really mind that they make crap, because the price indicates crap.
What I do mind is A brand companies making crap and charging the premium. EG; The Bosch silver bullit Coil made in the Brazilian Rain Forest by midgets on coke.
My dad always found an excuse why not to buy a Porsche, so I guess I am all out of excuses. |
^^^^^^Hehehehehehe^^^^^^
Scott "Houston, Tranquility Base here, the Eagle has landed" Silver 1984 M491 Sunroof Coupe |
Slippery Slope Victim
When my DME relay failed a few years ago I bought a Porsche branded relay from our host. It was no good right out of the box. I got a Kaehler as a replacement and no problems. I figured the Porsche one would be the best, not so. Maybe they use URO
MikeČ 1985 M491 |
I think it's unrealistic to expect multiple companies to keep manufacturing a part that is targeting a very small and shrinking market (pre-1990 Porsche and VW). We can be lucky if a company is still willing to make stuff at all. It can't be a very profitable business with these small production volumes.
abides.
I've only seen the originals fail due to solder joints cracking, which is easily remedied with a soldering iron and 5 minute of time. Do they fail in other ways?
Graham 1984 Carrera Targa |
There is no country of origin on either the relay or the box it came in.
Rick 88 Cab |
Eng-o-neer
The DME relay is just two standard automotive relays. All we all really need is an adapter that routes the pins of two Bosch relays to fit the Porsche socket properly. Cheap and excellent replacements forever.
Anyone know how to manufacture stuff? |
rick-l,
Can you flip that thing over and show the relays? Bob B |
Rick 88 Cab |
