Wow DME saved me
Geese just three weeks ago my wife's 1985 911 Euro coupe wouldn't start- cranked OK but no start. I pulled my spare DME from the hand rest pocket - installed - fired right.
Today driving home from work my 1985 911 Targa flat out quite a couple of times while driving. Restarted but ended up quitting before I reached home. Once again, pulled my spare DME from the handrest pocket- installed - and fired right up!! Dang - gotta love the older air cooled cars!! Less than $70 to fix two cars!! |
83 911 Production Cab #10
Great but LMFT4U...
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Member 911 Anonymous
Outstanding, now go get two more RELAYS
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Great story! That's exactly why every 3.2 Carrera owner should have a spare DME relay in their car.
Bruce '12 Carrera S DFI '84 911 Carrera |
Speaking of DME issues, anyone have access to wiring blueprints for a 1997 Varioram US market 993. Engine being installed into a 1980 SC chassis and having trouble connecting engine harness, main wiring harness through to the DME. Using PMS conversion bits but still having problems.
Thought we had a 55 pin setup (ROW) and have those wiring diagrams, but alas, the rebuilt motor is a US spec engine as is its engine, chassis harnesses and corresponding DME, ie 88 pin connections. Seeking a link to the 88 pin wiring diagrams. |
Always Be Fixing Cars
Funny how the DME Relay has the sound of something ominous and 911 specific like the IMS bearing failing. I keep a few standard Relays in my '95 ranger cause all old relays fail in the same fritzy way. No big deal, few seconds to swap and you're back in business.
'91 964 C4 - New Daily '73 Alfa GTV - 90% done 50% to go '65 912 - Welding in process |
Diss Member
Relays are awesome protection for switches in your car but they still fall under the heading of "They work right up to the point where they fail." (Just like everything else!!!)
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Counterclockwise?
I'm still trying to figure out what this has to do with geese .......
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
abides.
Or open up the original and re-solder the cracked solder joints.
Graham 1984 Carrera Targa |
