Wow DME saved me
Geese just three weeks ago my wife's 1985 911 Euro coupe wouldn't start- cranked OK but no start. I pulled my spare DME from the hand rest pocket - installed - fired right.
Today driving home from work my 1985 911 Targa flat out quite a couple of times while driving. Restarted but ended up quitting before I reached home. Once again, pulled my spare DME from the handrest pocket- installed - and fired right up!!
Dang - gotta love the older air cooled cars!! Less than $70 to fix two cars!!
Old 07-20-2016, 03:15 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Great but LMFT4U...
Originally Posted by 300cd300sdl911 View Post
geese just three weeks ago my wife's 1985 911 euro coupe wouldn't start- cranked ok but no start. I pulled my spare dme relay from the hand rest pocket - installed - fired right.
Today driving home from work my 1985 911 targa flat out quite a couple of times while driving. Restarted but ended up quitting before i reached home. Once again, pulled my spare dme relay from the handrest pocket- installed - and fired right up!!
Who Will Live... Will See
Old 07-20-2016, 04:51 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Outstanding, now go get two more RELAYS
'85 Carrera Targa
PCA/POC
Old 07-20-2016, 11:53 PM
DanielDudley's Avatar
Originally Posted by JJ 911SC View Post
Great but LMFT4U...
Thanks for relaying that message.
Old 07-21-2016, 12:15 AM
BER BER is offline
BER's Avatar
Porsche Crest
Great story! That's exactly why every 3.2 Carrera owner should have a spare DME relay in their car.
Bruce
'12 Carrera S DFI
'84 911 Carrera
Old 07-21-2016, 04:58 AM
Speaking of DME issues, anyone have access to wiring blueprints for a 1997 Varioram US market 993. Engine being installed into a 1980 SC chassis and having trouble connecting engine harness, main wiring harness through to the DME. Using PMS conversion bits but still having problems.
Thought we had a 55 pin setup (ROW) and have those wiring diagrams, but alas, the rebuilt motor is a US spec engine as is its engine, chassis harnesses and corresponding DME, ie 88 pin connections. Seeking a link to the 88 pin wiring diagrams.
Old 07-21-2016, 05:24 AM
Always Be Fixing Cars
Funny how the DME Relay has the sound of something ominous and 911 specific like the IMS bearing failing. I keep a few standard Relays in my '95 ranger cause all old relays fail in the same fritzy way. No big deal, few seconds to swap and you're back in business.
'91 964 C4 - New Daily
'73 Alfa GTV - 90% done 50% to go
'65 912 - Welding in process
Old 07-22-2016, 05:55 AM
Diss Member
Quicksilver's Avatar
Exactly! Had two Nissan pickups fail to crank the starter because of the unlabeled blue relay on the side of the engine compartment.
Relays are awesome protection for switches in your car but they still fall under the heading of "They work right up to the point where they fail."
(Just like everything else!!!)
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 07-22-2016, 08:38 AM
Counterclockwise?
I'm still trying to figure out what this has to do with geese .......
Rod
1986 Carrera
2001 996TT
Old 07-22-2016, 08:43 AM
gtc gtc is offline
abides.
gtc's Avatar
Or open up the original and re-solder the cracked solder joints.
Graham
1984 Carrera Targa
Old 07-22-2016, 10:22 AM
