Question Carrera cooler dimensions and pusher or puller fan?
Hi guys,
I am trying to track down the dimensions for the Carrera oil cooler, unfortunately it was put in my car before I could measure it. Does anyone know the dimensions (I did some searchs on this board alas no luck)
At the moment I am trying to track down a fan for it. I would prefer not to spend $300 US on the Porsche fan if I can help it. Am I looking for a puller fan that sucks the air from the cooler and in to the horn area at the front, or a pusher fan that blows the air through the cooler?
I have been recommended to go for a 12v "bike" fan, would this do the trick?
Thanks!
Old 12-29-2002, 03:14 PM
eion's Avatar
Send a message via ICQ to eion Send a message via Yahoo to eion
If you want a fan, I've got a spare one from a 964 after Parts Heaven screwed me over (long story). It's 12V, about 10" in diameter, and came off my AC condensor (very similar to the fan on the oil cooler). It looks to me like sucks air from the cooler.
'90 C2 Coupe - 104k miles
Old 12-29-2002, 03:22 PM
Moses's Avatar
The Carrera fan "pushes" air through the cooler. Otherwise it would be working against the flow of air as the car is moving.
I asked a similar question earlier:
Stoopid Carrera cooler question...
Old 12-29-2002, 03:50 PM
Thanks moses, I did a search but didn't see your thread. I shall track one down.
Old 12-29-2002, 04:17 PM
Buy them, sell them
Adam's Avatar
There was a guy selling fans for these coolers on eBay. He's in Kansas, I think, but they are 12v fans with an alloy frame and composite fan/blade assembly which reputedly flow 800cfm. Whisper quiet!
I bought one for my upcoming Carrera Cooler installation for US$40. Perfect dimensions for the cooler also.
1931 Oakland Eight Special Saloon
1985 BMW E28 525e (Euro 528e)
1989 911 Carrera Sport 3.2 G50 Cabriolet
Old 12-29-2002, 04:42 PM
Hi Adam,
Thanks for the info, I can't find him on Ebay, the closest I got was a 800cfm fan in Tampa, for $40 US (buy now) it has skewed blades, but it doesn't look composite. Its 13" in size.
Old 12-29-2002, 05:11 PM
Administrator
Jack Olsen's Avatar
Plenty of fans out there that will work. Check Pelican or www.racerpartswholesale.com .
Old 12-29-2002, 05:45 PM
Will a 10" fan fit in the front fender on the Carrera Cooler?
1977 3.0l Targa Carrera
Old 12-30-2002, 04:54 PM
----no---
I used a SPAL 7.5" fan, it looks to be the same size as the Bosch fan used as OEM, and it is a TIGHT fit. Fits straight across the width dimension of the cooler.
---Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 12-30-2002, 05:03 PM
Doh!
So a SPAL 7.5 Inch Pusher fan would do the trick?
Old 12-30-2002, 05:11 PM
Dana:
Don't understand the "duh"...
Just tryin' to save you some headaches from someone who's BTDT, and measured things.... no worries..
-Wil Ferch
Wil Ferch
Old 12-30-2002, 05:18 PM
Nah its Doh because I bought a 10 " fan this morning, only because some one else had recommended a 10 " and I didn't have any cooling measurements, looking at the cooler I thought, mmmm 10" is a bit big I think. Lucky I can take it back.
7.5" fans are hard to find here for some reason... must keep hunting
Old 12-30-2002, 05:21 PM
Rouxzy's Avatar
There is a fellow Pelicanite that sells the fans for $39.95. Here is his e-mail:
work - Kepperly@stanion.com
home - Keithepperly@earthlink.net
Good Luck
Tom
Ice Green '77 Targa 3.6 w/ Steve Wong chip
One Way To Get More Horsepower Is To Get A Bigger Horse!
"I couldn't find the sports car of my dreams, so I built it myself"
Ferdinand Porsche
Old 01-01-2003, 09:04 AM
Thanks!
Old 01-03-2003, 06:12 AM
