Difference between rev limiting and standard Rotor
The resistance on wires appears to be within spec. One a little low and one a little high. When checking resistance of the cap on an 81 SC O noticed that it spec'd as a rev limiting rotor per the Bentley manual. Is this rotor specific to a model and year or is it just an option.
Thanks Rob
Old 08-04-2016, 08:46 AM
ROW '78 911 Targa
timmy2's Avatar
If our car is a ROW car, then the rotor is all you have to protect you from over revving.
A US (and some other destinations) car/engine has an electronic rev limiting circuit in it.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 08-04-2016, 09:02 AM
They rarely work after all this time and are expensive.
I installed a RL rotor on mine.
Old 08-04-2016, 10:12 AM
So we can run either one?
Old 08-04-2016, 01:06 PM
yes
Old 08-04-2016, 01:09 PM
Thanks for the help!
Old 08-04-2016, 04:15 PM
safe's Avatar
Or you could skip it all together.
An SC have no problem going over the stock limiter, it's just mostly useless.
A limiter doesn't protect from the dangerous type if overrev, missed shift.
Magnus
Old 08-05-2016, 02:06 PM
This.
And that's probably the most common type of overrev.
Old 08-05-2016, 06:53 PM
Walt Fricke's Avatar
The main benefit of a rev limiter is in case the throttle gets stuck somehow. With steering column licks there is some risk in turning off the key at highway speeds, so putting the clutch in while braking will keep the engine from exceeding whatever the limit is until you feel safe turning the key off.
The mechanical limiters are pretty effective, and by bending the tab which holds the spring you can adjust where they cut the spark off.
Old 08-06-2016, 08:06 PM
