LinkBack | Thread Tools |
Rating: ![]() |
What is the most "Now I'm truly F'ed" thing that has happened during a 911 DIY ?
Just wondering what sort of disaster stories you guys have amassed over the years. Something that started minor (like an oil change) that turned into a major project (overtorque, stripped threads, cracked the block, etc)
You know, stuff like a screw extractor breaking off in some tight cavity where now.....you're F'ed. Engine has to come out for the thing to even be accessed with some fancy carbide or flame machine to remove the broken bit.
1986 Bosch Icon Wipers coupe. |
Brew Master
Was replacing head studs. All was going GREAT and then my crazy hard thread chaser broke off flush in the block. As luck had it, there was one drill bit harder than the thread chaser which my brother and I proceeded to break off inside the crazy hard thread chaser.
I'm sure there are others who have had a bigger oops but this was mine. |
Member 911 Anonymous
5 things that were just enough to make me want to sell the car:
1. Speed/Ref Sensor, 11 hours on my friend's concrete drive way trying to figure it out then eventually towed to shop, they did it in 1 hour ![]() 2. Crank shaft pulley dowel popped out because PO or his wrench did not properly torque it. I ended up hand shaving the mushroomed dowel hole and as a result for 5 years a wobble and engine vibration. Well, recent cam swap I fixed it properly with a Dial Gauge and proper tools, no longer vibrations. All due to a oil pissing out the center back, thank goodnes I found it but I was 3 hours from home went it started to pee ![]() 3. My first Clutch job and had the toothed washer in the wrong direction and it was hitting the fingers of the pressure plate, Engine Drop again? Yeap. 4. Before that forgot TOB guide tube inner seal, gear lube every where. This was me chasing my triangle of death leak on top. Doh! Yes, was related to #3. 5. Tried the $5.00 oil line fix, everything was going great until I burned right thru the brass with my torch. ![]() Then I grabbed couple of beers and calm my arse down ![]()
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 08-05-2016 at 04:50 PM.. |
Disaster of titanic proportions......
Didn't do it, just heard about it. Owner was trying to remove the block off the oil pressure sender while the sender was still mounted to the engine block. The popping sound he heard was not the fitting coming loose, it was the engine block breaking!! Not something that can be easily fixed so a small and inexpensive job became major bucks!
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
Yeah broke off exhaust manifold stud and then broke off extractor trying to remove it. Lucky that worked out at all.
Also had to do a R&R twice after screwing up a clutch. I think I did not get the throw out arm into the bearing.
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
We live and learn, huh?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
1979 911sc
Putting in a new brake light pressure switch ($8) and as I was wrenching the new switch in slowly I heard a "pop" as the die cast housing cracked and then fell into pieces, dumping brake fluid all over the frunk. This was just a couple of weeks after I bought the car and was my first repair. My heart sank. However, I quickly learned that most repairs on these cars are 1. Relatively inexpensive and 2. Not too hard to do. Its the only time the car has been out of service waiting for parts (only two days thanks to our host) in 6-1/2 years of nearly daily driving. For a 37-year-old sports car, this thing is built tough. Any other sports car of the era would have been sent to the scrap heap by now under the conditions in which I run my car.
1979 911sc 1969 Rover 2000 TC 2000 Ford Excursion 2015 Ford Transit 350 |
A friend just emailed this to me:
How did you resolve this?
Tell him to leave it alone if it is not leaking. Deal with it on the next oil change.
Fire
During the conversion from Webers back to MFI I was moving houses and the car was driveable but not well sorted yet.
Long story, about 3 blocks from the new house my wife and daughter pass me and are frantically waving and yelling that I was on fire. One of the MFI fuel lines was spewing slightly and the fire was contained below the engine tin on the heat exchanger. Luckily I was able to put it out with one bottle of water. Very close call and I really thought the end was near when I saw the flames.
Matthew - drove Nurburgring with wipers on and no rain 1969 911E SOLD ![]() 2002 996 Cabrio 1995 993 Carrera 4 SOLD 2004 Land Rover Discovery II G4 Edition (Sold ![]() |
Lol. The oil drain plug thing would kill me. I would Drain it back out just to find out what was up and get it over with. I know the torque specs are like 30 lb ft. I torque them just enough to crush the washer and a bit more. I don't think it's even 20 lb ft. Never had a problem.
1986 Carrera Coupe - 1987 W124 300E - 1999 Land Cruiser 100 - 2021 GLA250 |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Tools.
When I replaced the entire A/C on our '86,
I'm certain that on an overnight basis my tools grew little legs, and found a new place to hide............... Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 08-07-2016 at 12:23 PM.. |
My friend was using an angle grinder to clear paint for a roll bar install (sparks everywhere!), druring this time I was drilling out the rivets to the seat brackets, I went to far and hit a fuel line that runs in the tunnel, with the system being pressurized fuel came into the interior nearly instantly (not a small amount-I don't think I have ever moved so fast to get the grinder in his hands off the metal.
I don't have any major tragedies (yet), mainly because I've tried to limit the scope of work i do to try and minimize the collateral damage if/when I screw up. But man its good to hear some of these stories... Glad I'm not the only one who's felt that pit in my stomach and repeated to myself "no, no, no, this didn't happen..." in an attempt to calm my wildly spinning worst-case fear factory...
1983 Porsche 911SC 2004 Volkswagen MkIV R32 "Excuses are the nails holding together the house of failure." |
Had just gotten the 911, running rough, started a tune up. While doing the plugs, couldn't believe how hard they were to get out- when doing the last one, #6, it broke off in the head. Didn't sleep for 2 nights, wondering "what am I into here?"(with a 911- engine drop, thousand$$). Did research on the web and rigged up an E-Z out, held my breadth going in and...it slid out like butter.
74 911 Coupe 74 Triumph TR6 97 Jaguar XJ6 |
Was changing timing chain and the engine refused to be turned passed a certain point. It had to be dropped out of the car, turned sideway, fished out the chain, and started all over.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Breaking it off, however, seems like a whole new order of magnitude of dread to the level of "I may have just killed this car" I can't even imagine trying to get an EZOut into there successfully.
1986 Bosch Icon Wipers coupe. Last edited by sugarwood; 08-07-2016 at 11:40 AM.. |
Decided to adjust gear linkage (915) because, ya know, I can make it more better. Thinking I've nailed it decide to go for a drive. Wait, it's stuck in reverse and though the lever moves no gears can be selected. Hit the Pelican and thankfully found some previous experiences of similar. The cause, it was explained, was the little rod that engages with the reverse light switch was stuck in the out position. Remedy, jack up the car, climb under there and one handed remove the reverse light switch. And of course once it's out a large cup full of gearbag oil comes pissing out. Anyway I can feel the rod protruding and finger power is not enough to push it in. So I find a drill bit about the same diameter to seat against the rod, but there's no room to swing a hammer to tap the farker back in. I was eventually able to reseat it with the handle of a vice grips and much cursing. And all the time it's getting slippier under there than two chicks in a mud wrestling contest. Eventually got it buttoned back up, oil cleaned up, took a shower. Then started the gear linkage adjustment again, this time it worked.
But wait, there's more. Two years later installing a factory short shifter I DID IT AGAIN. Reread the first paragraph to see how I fixed it this second time.
J Mac Current 0 Sold - 67 911T Coupe racecar, 87 911 Cabriolet, 85 911 Targa, 98 Boxster, 95 993 Coupe, 88 911 Cabriolet, 75 911 Carrera #144, modified |
ASE Master Tech - 35 yrs
mid-'90's: bought a new 2.7 case from a fiend (friend)(both) who did a lot of 911 parts trading - (the case was really NEW - no numbers) - had been timeserted & race prepped by Ollies (with recpts) - then i paid to have it oil passage modded by Ted Robinson - got the thing completely together (with RS p&c's) - and installed in my 914-6 as long block (no intakes or carbs yet);
then i went to install the various external sensors & senders, discovered the threads in the case for the oil pressure switch (the one at the flywheel end) were completely boogered & hogged out - which in quick hindsight was probably why the case was being traded around - solved it with a large soaped pipe tap, and a lot of careful incremental tapping just like they taught me in shop class - then made/installed a larger brass adapter, with thread sealant, to fit the oil psi sender - did it all with the engine in the bay & much body contortion it never leaked!
"... I am German, and if it has no logic it's meaningless." 914 & 914-6 parts FS 03-2021 ![]() 911 parts FS 2022 ![]() |
Thread Tools | |
Rate This Thread | |
