81 SC front Bilstein struts
GoodMorning
Time to restore my 911 after sitting in my garage for 8 years. I've dropped the entire front suspension and my question is this How do you remove the strut insert. I've spoke with our host on replacement struts and they are ready to ship. Do I need to remove the roll pins? I've read some conflicting advice here in researching past threads. Some say you put the nut back on the strut end with a big washer and tap on it to remove the strut from the housing. 81 911 SC 76 911 S 66 912 65 912 71 914 70 914 |
Roll pins hold the insert's shaft in the housing. Put the smooth side of the roll pin against the shaft on installation, not the grooved side.
if you have the green bilsteins, you need to remove the roll pin with a specific punch. i think its called a pin punch, the face of the punch has a dimple that fits into the center of the roll pin. sears has the right one. and when you reinstall them what john said about the orientation of the roll pin
Jason 81 SC 97 328is 87 Jeep Comanche (RIP) |
