Wer bremst verliert
Dizzy trigger options for a 6-pin CDI
I want to use a good 6-pin CDI unit I have with a 231.184.004 distributor, which I think is 1973.5-77. Clockwise.
I understand Crane Optical outputs a square-wave signal the original Bosch CDIs will not work with. I have not received clear information about whether the Pertronix i/ii/iii put out a signal the 6-pin CDI will recognize. Are there any options, other than backdating the distributor to points? Could I use an tach adapter like MSD, Tach Adapt and Pertronix all offer to adapt the signal to the 6-pin CDI? Little help please? Thanks!
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
The 184 004 is a points distributor so it needs to be used with a 3-pin CDI. The 6-pin CDI is designed for the SC type distributor with the reluctor wheel. The input trigger is different.
I would contact Bob Ashlock and see if he has any ideas but I don't think those can be used together. The Crane or Pertronix just replace the points but provide the same input for the 3-pin CDI
1970 911E Sportomatic Albert Blue 1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI 1973 911E Glacier Blue 1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI |
Wer bremst verliert
To your knowledge, can I put an SC reluctor wheel and sensor in the 004 dstributor?
My alternative seems to keep the crane trigger in there and relpace the MSD 6 I had to use for another car. It worked flawlessly, I was just hoping t use the Bosch CDI I have.
There is no way to put the SC reluctor wheel in the 004 distributor. The 184 004 is the "RS" distributor so it's worth some money. They don't come up for sale that often but would probably bring $500+ Why don't you just buy a good used or rebuilt 3-pin CDI and sell the 6-pin unit?
1970 911E Sportomatic Albert Blue 1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI 1973 911E Glacier Blue 1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI Last edited by jbell959; 08-15-2016 at 07:17 AM.. |
I agree that you'd be better off to sell the Bosch CDI and replace it with something more current.
Maybe an MSD which will trigger off points or a Pertronix.
Mark www.exotechpower.com 1981 Targa-messed with. 91 C2 supercharged track rat Radical Prosport-irritates the GT3 guys 40 years of rebuilding services |
ROW '78 911 Targa
Use an SC distributor and change the gear drive?
You can't spin the SC distributor clockwise... you would need to change the gear drive on the crank. The only reluctor type distributor that works is the early 3.0 turbo one that is the same reluctor type but spins clockwise. Unfortunately those are hard to find.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
ROW '78 911 Targa
Good info. Thanks
You can use any 'coil' based pickup with a 6 pin box. Mallory sell one in the States but not sure if it will fit in the housing. We've used this recently on a 3.0 CSL BMW.
Of course, if you used one of our CDI+ units, you could lock the springs and do the timing electronically. It will work with any kind of trigger and your tacho will work correctly. You'd get more HP from the multi spark too!
www.classicretrofit.com |
I presume the 6 pin can also be triggered by points? If so, use the Crane box to switch the current to the points connection on the 6 pin CDi. You will end up running two boxes (the Crane and the Bosch) but it should work fine. To find out how, look at how an MSD is triggered by a pertronix module and once you understand how that is done, the equivalent with the Crane and Bosch should be easy. Or, contact Crane and ask them for a diagram. Fred
Unfortunately, the 6 pin can't be triggered by points as the input is a zero crossing detect circuit.
Wer bremst verliert
Update: I went to put the 6-pin CDI away and found a good 3-pin. I think I have a problem when I am finding parts I had no idea I had...time for a garage clean-out and pelican classified sale...
Selling the 6-pin?
Sigurd 73.5T 3.2SS EFI X87 944S 3.0 |
