-   -   Post your ITB Setup (http://forums.pelicanparts.com/porsche-911-technical-forum/925845-post-your-itb-setup.html)
SiracHaile 05-24-2025 06:40 AM
Montauk, very cool that you were able to drive the gauges with the ecu. I thought about that but I didn’t want to mess with figuring it out. I’m still using the factory style sensors and the modern sensors keeping the systems separate. Would have been smarter to do what you did.
On the positive side, I finished building my “motorsports grade” wiring harness. Took time to properly plan and route. I understand why people charge what they charge for these now.
https://uploads.tapatalk-cdn.com/202...daa71afafc.jpg
https://uploads.tapatalk-cdn.com/202...c1db6cbff2.jpg
montauk 05-24-2025 11:16 AM
Nice work. I bought the pre-made flying harnesses.
montauk 05-28-2025 06:08 AM
A big oops by me. I would have sworn that I had set my ECU to use throttle position and not MAP. Well, I didn't. I was looking into a setting that Haltech has for "MAP Prediction/Fuel Film Enable" when I saw that I had left "Fuel Load Type" set for MAP. So that's nearly 150 miles running based on MAP. The only problem I had was odd behavior at low speeds particularly starting from a dead stop. I changed to TPS and drove it about 15 miles with no low speed problems. But I did notice that deceleration could be a bit too quick. More settings to tweak.
http://forums.pelicanparts.com/uploa...1748436955.png
nospiners 12-03-2025 05:58 PM
This is my set up , 3.4 twin spark , Rasant Itb’s AEM Infinity Ecu , Clewett Cam/crank sensors Coil on plugs , billy boat headers and exhaust .Almost ready for a first crank
img]http://forums.pelicanparts.com/uploads26/IMG_15731764813287.jpg[/img]
http://forums.pelicanparts.com/uploa...1764813381.jpg
Jeff Alton 12-03-2025 10:52 PM
^^^^ Looks like PMO throttle using the Weber style mandifolds...
We have used AEM a lot in the past,, but find the ECU's difficult to source from time to time.
Engine looks nice, keep us posted about the first start!
Cheers
nospiners 12-04-2025 12:47 PM
http://forums.pelicanparts.com/uploa...1764880895.jpg
A system i bought from a friend ,off a crashed car with no miles on it . We run it on a stand recently without software hookup , run fine ,now almost ready for a first start in the car , still looking for the software so i can check and fine tune myself.
Pork Chops 12-04-2025 02:41 PM
Hey just an FYI. I had significant issues getting my AEM ECU to drive a twin spark set up. Single spark on and other car was OK. In the end we junked it and went Haltech which we were immediately able to tune. It was a while ago and I can’t recall the exact AEM ECU model but it was supposed to be able to do the job. I’m only telling you this in case you have similar issues as I wasted a lot of time trying to resolve the unresolvable. All the best.
nospiners 12-04-2025 05:40 PM
(Hey just an FYI. I had significant issues getting my AEM ECU to drive a twin spark set up. Single spark on and other car was OK. In the end we junked it and went Haltech which we were immediately able to tune. It was a while ago and I can’t recall the exact AEM ECU model but it was supposed to be able to do the job. I’m only telling you this in case you have similar issues as I wasted a lot of time trying to resolve the unresolvable. All the best.)
I have heard the horror stories and did my re4search . This particular system has 20 dyno hrs on it and should be fine (i hope). I have gotten in touch with Andrew at Rasant and his boss now at
G2 Motorsports. Although they cant provide support for the earlier systems , they haver been very helpfull. Fingers crossed !!
AlKidd 12-04-2025 06:49 PM
Did you use COP for the bottom plugs too? I did COP for the top and CNP for the bottom.
nospiners 12-05-2025 06:50 AM
Yes , coil on plugs top and bottom..
ToySnakePMC 12-05-2025 11:27 AM
Oooh. I like that idea. Do you have a build thread here or some pics and specs you can share on your COP and Coil-Near-Plugs? I just finished dual COP on current car - and it runs fine. But I like your idea of keeping the lower coils further away from the headers. That's a hot little area down there. Thx, Patrick
Showdown 12-05-2025 02:15 PM
You can fabricate heat shields with some aluminum and line them with heat shield insulation to keep the COPs less heat soaked... Just make sure that they still allow airflow...
nospiners 12-05-2025 03:04 PM
No build thread here , i have pictures , the Billy boat headers stay further away
http://forums.pelicanparts.com/uploa...1764975816.jpg
That was taken right before the engine went in the car.
ToySnakePMC 12-05-2025 03:29 PM
Ours look somewhat similar. Camera angle may distort the perspective, but it seems headers and COPs are closer than they appear. These are 1-5/8" Patrick Motorsports headers with eBay's finest $15.00 header wrap, lol !
http://forums.pelicanparts.com/uploa...1764977258.jpg
nospiners 12-05-2025 04:27 PM
My wrap was Amazon's finest , we have a lot in common , lol..
AlKidd 12-09-2025 02:57 PM
I cant claim credit for it. Clewett had all the mounts. Simple bolt on.
rattlsnak 12-09-2025 07:08 PM
Many years ago!
http://forums.pelicanparts.com/uploa...1765336048.jpg
Black 993 12-10-2025 08:11 PM
You guys with lower COP's, are you using a bracket to secure them in? I'm converting my 993 to COP and need to figure out a bracket (stock plastic valve covers).
nospiners 12-11-2025 06:18 AM
I'm not using brackets , mine just clip on with no issues , needing effort to pull them off..
AlKidd 12-11-2025 06:34 AM
I was worried about them falling out and landing on a hot header which is why I went with CNP for the bottom. I agree the COP's fit firm but thats cold and not bouncing around a bumpy autocross. Didnt want to take a chance.
