Post your ITB Setup
Hey PeliCANS,
I've been researching ITB set ups for a while on the forums, and while there are GREAT threads here, I noticed there was no single collective thread on everyones set ups. I'd like to get a general idea of what you've done to set it up, so I'll list a few things pertinent to a proper set up and we can go from there. Feel free to add extra info and of course PICTURES! This will be aimed at more of the DIY crowd than people who have systems for sale, but post what you got anyhow. ITB source: (for example GSXR-600 TB, home-brew, Jenvey, etc.) ECU : (Megasquirt Version 67, etc.) Injectors Used: ( Manufacture, flow rate) Manifold source: ( Stock weber, zenith, home-brew, etc) Fuel Pump: Pressure Regulator: Ignition / Crank trigger: Rough total cost for a running set up: Any info you gained that wasn't on the forum. Thanks Pelicans, hope to see some awesomeness. - Steve |
sub'ed, i am working on this as well.
I compiled parts for GSXR 1300's ITB's, and I'd say I'm $600-800 in.
Already have MegaSquirt II v3.57, twin 044 pumps, stock 3.2 FPR, 80lb Deka injectors, GSF crank trigger system with 36-1 trigger wheel, VR mount, and dizzy block off. I'm turbo, so I have to build logs atop and appropriate piping from IC. |
Is there a link to some of these set ups? Thx
GSXR-1000 ITB's, VEMS ECU. Have made several sets for 993, 911 3.2, 2.7.
Last iteration is for my 2.4 S with E46 M3 electronic actuator and E46 electronic pedal (to get rid of the long throttle cable). Tested fine on the bench. |
ITBs
I started buying all the bits and 3D modeled my own system, but opted to go carbs. In the end, I felt that the cost was too close to carbs and that my home brew EFI will have no value to others in the end.
Home-brew ITB setup Triumph 900 ITB's $50 Tubing 100 Flanges 50 Bungs 50 boots 50 venturi 200 ECU 1375 Injectors 250 Fuel pump 150 Regulator 150 Hardware / lines 100 Welding / fab 250 Filter assys 130 Eids 200 Tuning time 0 Crank trigger 300 Throttle linkage 100 Wide band o2 200 Total $3,705 Jenvey ITB with PE-LTD ECU ITB 3200 Ford EIDS 125 Injectors 200 TPS 100 ECU 1375 Wideband 300 Wires 300 Harness 143 Crank Trigger 300 Total $6,043 Vems with Borla TWM / Borla ITB 2300 Vems 1535.91 COP 460 TPS 100 Crank trigger 220 Pickup sensor 50 Injectors 250 Total $4,915 PMO / Dist Carbs 4100 Dist 1300 wires 300 6-AL2 CDI ignition 500 Coils 90 Total est $6,290 |
Here's my twist on an ITB setup from TurboKraft, powered by Rasant Products AEM Infinity ECU kit:
http://forums.pelicanparts.com/uploa...1471872889.jpg |
Beautiful Marc!
What green is that? it's strikingly similar to the Velvet Green on my 69. http://forums.pelicanparts.com/uploa...1471875747.jpg |
Built on 911E throttles enlarged to 40mm by Eurometrix, 39mm ports. Bells are for 44mm Weber (VW). Stacks are 1/2 thick wall, then tapered to fit.
http://forums.pelicanparts.com/uploa...1471876206.jpg |
https://www.youtube.com/watch?v=SpPM1SZL_rc regards, al |
It photographs nicely but the pics just don't do it justice! Wonderful depth and tone. |
Here's mine – I'll have to check the details if anyone is interested, but basically it's a Haltech running ITBs with twin plug heads.
http://i.imgur.com/k7Vcxhcg.jpg |
3.0
Here's a 3.0 I built a few months back.
JE 9.5:1 E-ish cams x-faktory S3-EFI/ITBs Rasant engine management COPs headers sport muffler http://forums.pelicanparts.com/uploa...1471963320.jpg http://forums.pelicanparts.com/uploa...1471963419.jpg And a 2.7S recently shipped..... JE 9.5:1 TWM/Borla 40mm ITBs Early E-cams MS3X Crankfire/EDIS Early headers/heat exchangers sport muffler http://forums.pelicanparts.com/uploa...1471963680.jpg http://forums.pelicanparts.com/uploa...1471963712.jpg Al Kosmal the x-faktory koz@x-faktory.com RGruppe #669 www.x-faktory.com |
I have another 3.0 and a 2.7 headed my way.........both of them will be rebuilt and turned into EFI/ITB hipo engines.
regards, al |
Here's the Rasant Engine Management kit installed on PMO 46mm ITB's
http://i72.photobucket.com/albums/i1...8FD4DBA47C.jpg |
It's a ceramic coating. I can't recall what color, it looks like a protective coating with the natural finish. There's a guy here in So Cal that does it.
Thanks, I do fan restorations as well and use Cerakote.
I'm picking up a 2.7 RS longblock this weekend and will need Webers or an EFI/ITB system for it. |
I just acquired a 1997 engine in an 88 Carrera Coupe -3.6 ,with
KMS engine management and itb's-System is a KMS25 sport cams ,Rarly headers 2/2 rsr muffler w jethot coated headers and muff. MP25 management ECU Specs are listed below-(they are big with the BMW guys) System has been used in a exclusive use track car for the last 5-6 years with 100 % reliability. <http://kms.vankronenburg.nl/wp-content/uploads/2012/03/01-01-01-0001prof.j pg> The KMS MP25 ECU is an affordable and efficient engine management system. By using the minimum of sensors, three auxiliary outputs, one auxiliary input and a wide range of functions, the KMS MP25 ECU can cope with 90% of all types of Otto engines. These basic functions make the MP25 a simple, reliable and effective engine management system at a very competitive price. ‘This is a engine management system designed by engine people to be used by engine people. Anyone who understands the mechanics of the Otto cycle, should be able to set up and use this system with little difficulty.’ Features: * Complete engine management system up to 10 cylinders * Self-learning lambda control in combination with KMS UEGO controllers * Engine diagnostics * Short cut protected outputs * Serial RS232 communication * External dashboard (KMS CAN display in combination with interface) * 2 engine load sensors * Analogue input (2nd lambda, gearbox position, G-force sensor, EGT, etc.) * 3 auxiliary outputs (Shiftlight, water-injection, cooling fan, etc.) * Pit lane limiter (variable) * RPM limiter * A.L.S. (variable) * Powershift (separate delay and cut-off time for each gear) * Boost control * Launch control (variable) * Idle control |
^^^^^ Not a good sign their webpage is not active!!!
I have been thinking of going with ITB's after speaking with Al about a rebuild.
At this point I have a pretty good running 3.2 (other than oil leaks) with Motronic DME. What should I expect changing to ITB's and how would they compare to the Motronic FI currently on the car. Thanks, Rich |
Hey Al, do those S3 ITB's come polished? Is there a reason they aren't lined up and perpendicular?
I'm shopping around for a running 3.2. In the future, ITB/EFI/EMS is a definite thing. Quote:
Still not done Making the plenums and intercooler. But here is the link to mine, it's a turbo so a little different . I made my own manifolds got the ITB's from Jenevy and also the linkage.
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/763281-well-i-its-finally-time-pull-out-efi-swap-will-long-one.html |
ITBs
http://forums.pelicanparts.com/uploa...1472061598.jpg http://forums.pelicanparts.com/uploa...1472061614.jpg http://forums.pelicanparts.com/uploa...1472061628.jpg |
they seem to be not so much into social media. Velocity stacks for the M cars are delicious. |
thanks....give me a shout and we can discuss. regards, al |
The KMS stuff seems way legit. I had them quote me the setup, before I decided to stick with carbs and a 12 plug.
https://www.youtube.com/watch?v=Fqkzn5IMOFI |
Dzug Dyno
Here's a dyno run of the Dzug 3.2SS...the dyno sheet is a composite that shows the before and after. Before is Bosch CIS, after is my x-faktory EFI/ITB system...no other changes were made. (dotted lines are before, solid lines after)
a couple vids..one of pre-dyno road test and one of dyno run https://www.youtube.com/watch?v=pxXwaL_TdmY https://youtu.be/xaj0FyEmc68 http://forums.pelicanparts.com/uploa...1472090279.jpg http://forums.pelicanparts.com/uploa...1472090291.jpg I wish those guys were still around...they had mad skillz.... regards, al Al Kosmal the x-faktory koz@x-faktory.com RGruppe #669 X-Faktory - Home |
http://i1244.photobucket.com/albums/...psa6dyyn3n.jpg |
Ferrino, thanks for the reply.
That sounds good, I would be looking for the same characteristics. Rich |
I have been installing EFI using MFI stacks. This retains all of the factory induction for early cars. Includes flex line fuel feed like the RSR-MFI systems.
Currently building 2X 3.0s and a 2.8 with the same system. This does require MFI ports installed into the head. Available from our host. http://forums.pelicanparts.com/uploa...1399057369.jpg |
| All times are GMT -8. The time now is 01:31 PM. |
