I just acquired a 1997 engine in an 88 Carrera Coupe -3.6 ,with
KMS engine management and itb's-System is a KMS25 sport cams ,Rarly headers 2/2 rsr muffler w jethot coated headers and muff. MP25 management ECU Specs are listed below-(they are big with the BMW guys) System has been used in a exclusive use track car for the last 5-6 years with 100 % reliability. <http://kms.vankronenburg.nl/wp-content/uploads/2012/03/01-01-01-0001prof.j pg> The KMS MP25 ECU is an affordable and efficient engine management system. By using the minimum of sensors, three auxiliary outputs, one auxiliary input and a wide range of functions, the KMS MP25 ECU can cope with 90% of all types of Otto engines. These basic functions make the MP25 a simple, reliable and effective engine management system at a very competitive price. ‘This is a engine management system designed by engine people to be used by engine people. Anyone who understands the mechanics of the Otto cycle, should be able to set up and use this system with little difficulty.’ Features: * Complete engine management system up to 10 cylinders * Self-learning lambda control in combination with KMS UEGO controllers * Engine diagnostics * Short cut protected outputs * Serial RS232 communication * External dashboard (KMS CAN display in combination with interface) * 2 engine load sensors * Analogue input (2nd lambda, gearbox position, G-force sensor, EGT, etc.) * 3 auxiliary outputs (Shiftlight, water-injection, cooling fan, etc.) * Pit lane limiter (variable) * RPM limiter * A.L.S. (variable) * Powershift (separate delay and cut-off time for each gear) * Boost control * Launch control (variable) * Idle control |
^^^^^ Not a good sign their webpage is not active!!!
I have been thinking of going with ITB's after speaking with Al about a rebuild.
At this point I have a pretty good running 3.2 (other than oil leaks) with Motronic DME. What should I expect changing to ITB's and how would they compare to the Motronic FI currently on the car. Thanks, Rich |
Hey Al, do those S3 ITB's come polished? Is there a reason they aren't lined up and perpendicular?
I'm shopping around for a running 3.2. In the future, ITB/EFI/EMS is a definite thing. Quote:
Still not done Making the plenums and intercooler. But here is the link to mine, it's a turbo so a little different . I made my own manifolds got the ITB's from Jenevy and also the linkage.
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/763281-well-i-its-finally-time-pull-out-efi-swap-will-long-one.html |
ITBs
http://forums.pelicanparts.com/uploa...1472061598.jpg http://forums.pelicanparts.com/uploa...1472061614.jpg http://forums.pelicanparts.com/uploa...1472061628.jpg |
they seem to be not so much into social media. Velocity stacks for the M cars are delicious. |
thanks....give me a shout and we can discuss. regards, al |
The KMS stuff seems way legit. I had them quote me the setup, before I decided to stick with carbs and a 12 plug.
https://www.youtube.com/watch?v=Fqkzn5IMOFI |
Dzug Dyno
Here's a dyno run of the Dzug 3.2SS...the dyno sheet is a composite that shows the before and after. Before is Bosch CIS, after is my x-faktory EFI/ITB system...no other changes were made. (dotted lines are before, solid lines after)
a couple vids..one of pre-dyno road test and one of dyno run https://www.youtube.com/watch?v=pxXwaL_TdmY https://youtu.be/xaj0FyEmc68 http://forums.pelicanparts.com/uploa...1472090279.jpg http://forums.pelicanparts.com/uploa...1472090291.jpg I wish those guys were still around...they had mad skillz.... regards, al Al Kosmal the x-faktory koz@x-faktory.com RGruppe #669 X-Faktory - Home |
http://i1244.photobucket.com/albums/...psa6dyyn3n.jpg |
Ferrino, thanks for the reply.
That sounds good, I would be looking for the same characteristics. Rich |
I have been installing EFI using MFI stacks. This retains all of the factory induction for early cars. Includes flex line fuel feed like the RSR-MFI systems.
Currently building 2X 3.0s and a 2.8 with the same system. This does require MFI ports installed into the head. Available from our host. http://forums.pelicanparts.com/uploa...1399057369.jpg |
| All times are GMT -8. The time now is 07:17 AM. |
