Montauk, very cool that you were able to drive the gauges with the ecu. I thought about that but I didn’t want to mess with figuring it out. I’m still using the factory style sensors and the modern sensors keeping the systems separate. Would have been smarter to do what you did.
On the positive side, I finished building my “motorsports grade” wiring harness. Took time to properly plan and route. I understand why people charge what they charge for these now. https://uploads.tapatalk-cdn.com/202...daa71afafc.jpg https://uploads.tapatalk-cdn.com/202...c1db6cbff2.jpg |
Nice work. I bought the pre-made flying harnesses.
A big oops by me. I would have sworn that I had set my ECU to use throttle position and not MAP. Well, I didn't. I was looking into a setting that Haltech has for "MAP Prediction/Fuel Film Enable" when I saw that I had left "Fuel Load Type" set for MAP. So that's nearly 150 miles running based on MAP. The only problem I had was odd behavior at low speeds particularly starting from a dead stop. I changed to TPS and drove it about 15 miles with no low speed problems. But I did notice that deceleration could be a bit too quick. More settings to tweak.
http://forums.pelicanparts.com/uploa...1748436955.png |
This is my set up , 3.4 twin spark , Rasant Itb’s AEM Infinity Ecu , Clewett Cam/crank sensors Coil on plugs , billy boat headers and exhaust .Almost ready for a first crank
img]http://forums.pelicanparts.com/uploads26/IMG_15731764813287.jpg[/img] http://forums.pelicanparts.com/uploa...1764813381.jpg |
^^^^ Looks like PMO throttle using the Weber style mandifolds...
We have used AEM a lot in the past,, but find the ECU's difficult to source from time to time. Engine looks nice, keep us posted about the first start! Cheers |
http://forums.pelicanparts.com/uploa...1764880895.jpg
A system i bought from a friend ,off a crashed car with no miles on it . We run it on a stand recently without software hookup , run fine ,now almost ready for a first start in the car , still looking for the software so i can check and fine tune myself. |
(Hey just an FYI. I had significant issues getting my AEM ECU to drive a twin spark set up. Single spark on and other car was OK. In the end we junked it and went Haltech which we were immediately able to tune. It was a while ago and I can’t recall the exact AEM ECU model but it was supposed to be able to do the job. I’m only telling you this in case you have similar issues as I wasted a lot of time trying to resolve the unresolvable. All the best.)
I have heard the horror stories and did my re4search . This particular system has 20 dyno hrs on it and should be fine (i hope). I have gotten in touch with Andrew at Rasant and his boss now at G2 Motorsports. Although they cant provide support for the earlier systems , they haver been very helpfull. Fingers crossed !! |
You can fabricate heat shields with some aluminum and line them with heat shield insulation to keep the COPs less heat soaked... Just make sure that they still allow airflow...
http://forums.pelicanparts.com/uploa...1764975816.jpg That was taken right before the engine went in the car. |
Ours look somewhat similar. Camera angle may distort the perspective, but it seems headers and COPs are closer than they appear. These are 1-5/8" Patrick Motorsports headers with eBay's finest $15.00 header wrap, lol !
http://forums.pelicanparts.com/uploa...1764977258.jpg |
My wrap was Amazon's finest , we have a lot in common , lol..
| All times are GMT -8. The time now is 08:43 AM. |
