Very cool Jamie.
regards, al |
Efi/mfi
I did make a proto EFI/MFI system on a 3.0 build.....................a slightly different take on it...
http://forums.pelicanparts.com/uploa...1472572731.jpg There is fire............... https://www.youtube.com/watch?v=SpPM1SZL_rc regards, al This was really a prototype, as seen in the pix and video....a one-off design to try out a new idea, using aluminum Turbo spacers, machined for EFI injectors, MFI t'bodies (I bored them out to port match) and Weber stax........worked great and I eventually completed the system. However, I was using parts that I had sitting on the shelf for years and while i was building this proto....the price of MFI bits went through the roof, making it not very cost effective approach. Speaking of old parts, sitting on the shelf....these will be incorporated into an EFI system one of these days.....stay tuned. http://forums.pelicanparts.com/uploa...1472573317.jpg |
JENVEY ITB's
Here is my 3.2L before rebuild, with 48mm Jenveys.
http://forums.pelicanparts.com/uploa...1472587889.jpg |
Man I wish I had that muffler!!!!
Todd |
Fly is that a gt3rs muffler? On a 3.2? Using what headers? Are you using Motec? Thanks Sent from my iPhone using Tapatalk |
what does that do and what are the advantages Steve? |
Better midrange torque, Steve correct me if i am wrong. Also would this be applicable on 3.2 motors? Another question is a switch over on 4500+ rpm possible like the watercooled cars with this set up? Sent from my iPhone using Tapatalk |
Has anyone used shaftless ITBs - my engine builder had the below made up and is recommending them due to being able to run narrower bores compared to say Jenveys to maximise midrange - with William Knights input I'm thinking of running them with a 993 intake and t-piece filter as shown by Steve Weiner above. http://uploads.tapatalk-cdn.com/2016...775de5b9df.jpg http://uploads.tapatalk-cdn.com/2016...0982066cfd.jpg |
This thread is great. I have been wanting to do a ITB/EFI setup for a long time.
I have a curiosity question though. Has anyone ever done an intake plenum with ITBs with a supercharger? Just wondering. |
I Am leaning toward this kind of setup. I love the look of the ITBs without the air filters though. I'm guessing with this nice-looking plenum setup you get a fairly even torque curve if you cam it correctly?
So many options, so little money... Quote:
My setup:
http://i132.photobucket.com/albums/q...pse8c2b5a4.jpg On the dyno: https://www.youtube.com/watch?v=vPH4HrAljv0 More info: otto in norway's Garage :: Black bastard |
I don't think Flys is a 3.2 anymore, now using 4.0 Gt3 crank IIRC We're thinking of using 42mm with a gt3 crank and my current 3.4 making 3540cc. I can't recall if barrel or guillotine. FWIW It had a much smoother action than the PMO linkage on another car in his garage, at least when cold. I think the piece in the pic has to face forwards in cars without tails due to interference ? |
I have seen the filters/mesh screens on top of the ITBs before. I like that look too.
The big-bore plenum idea is great, and if you have room in teh back under the decklid you can put the air cleaner in back instead of up front. Quote:
My '87 Carrera is not a 3.2L anymore... All internals are 997 GT3, crank, con rods, oil pump, intermediate shaft and cam gears, etc, etc. The pistons and cylinders are LNE Nickies with 102mm bore and titanium wrist pins. Valves are 993 RSR (on heavily modified heads), 326/318 degrees cams and modified valve rockers. So the 48mm Jenveys will be perfect for the 3.8L. The ECU is Canems from the UK. The muffler is a 997 GT3 4.0 OEM titanium, with Fabspeed RSR headers. The gear box is modified with lower gears, steel synchros and shifter forks, limited slip, etc etc, all from Guards Transmission. The car is now 2,500lbs, but I will get rid of another 300lbs. The goal is 400Hp and 1,000kg (2,200lbs). All on a matching numbers car that looks like factory on the outside...
Nothing's original, but the numbers match...
Mick_D, the engine and gear box cases are still the original, hence a matching numbers car...
Sure, that's what I said. nothing-original-but-the-numbers-match.
Impressive Fly911
[QUOTE=sp_cs;9262236]No offence intended as i know little about not very much, but is that dyno plot accurate? That's showing 30-40 bhp/torque gains with your upgrade package? Care to detail the changes?
sp_cs....no worries.........I had posted a composite to make it easier to see before/after, but here are the actual dyno runs, and description as originally posted by the Dzug guys..... """Thats a whopping 24hp and 30(!)lb/ft gain over the stock CIS for an identical motor, SSIs and megaphones. The car has been transformed, pulls crisply and SOUNDS amazing with the ITBs. There are still gains to be had with tweaking the timing, and we could probably get more out of her still if we had coil packs, but not bad """ http://forums.pelicanparts.com/uploa...1472661335.jpg http://forums.pelicanparts.com/uploa...1472661360.jpg here's a link to the original post http://forums.pelicanparts.com/porsche-911-technical-forum/741911-d-zug-tours-rsr-dyno.html and dyno pull vid https://www.youtube.com/watch?v=QdXp67tdbbE https://www.youtube.com/watch?v=xaj0FyEmc68 https://www.youtube.com/watch?v=hIehm1WuxPI&feature=youtu.be |
Incredibly helpful, thank you!
I've got a fresh stock SC (small port) build that I'm getting running on carbs, but I think will be ITB in the future. Tried it once before in the 90's with a TEC3 ECU and TWM but never got it running well. Quote:
Looks like the juice was worth the squeeze. Could probably go even better with a bit more cam. Regardless, I like it. Currently waiting for the MFI machine work to be completed for the 2.8 I'm building.....the good guys are always backed up. |
Key to getting ITB engine running perfectly is to have at least MAP compensation table+MAT compensation table on top of Alpha-N or the best method is to have MAP/Alpha-N hybrid load. |
Also, It is not so difficult you get ITBs to run well with SD algorithms provided you understand the scaling required to match the non-linear MAP signal versus load. I do this often with very nice results. As they say... "give the engine what it wants". There are many solutions to the ECU and tuning component of these installations just as there are hardware and intake solutions. One size does not fit all. |
Using a Resonance Plenum over ITB's results in a 25-45 lbs-ft torque boost from 2K to about 5500 RPM, all things being equal.
The effect is quite noticeable and works on all 911 engines. :) :) Naturally, the plenum must be sized (matched) to the displacement. |
has anyone done back to back test with the a 964 plastic mani ITB 3.2 dyno to see were the gains are? i would assume its helps a lot for low rpm running issues with the ITBs. i have a 3.2 twin plug, 964 cams now and plastic 964 mani sitting on the self. |
What engine management are you going to use with that 964 manifold. And it is not a direct fit. Are you going to use it with itbs? Sent from my iPhone using Tapatalk |
BTW, I always give engine what it wants ;) |
Very cool information from all.
I've bought 993 intake halves as a starting point. Sending to William Knight for his t-piece filter arrangement to be made up. |
I'm going to try that 1st and experiment. If it doesn't work out, I'll try jpnovaks tried and true method. :) |
Next phase would be a stand alone followed by ITB's. No know itb's aren't worth the $ if you aren't spinning above towards 8k but the look and sound fantastic. |
basically once you replace the standard CIS( toilet plunger) with EFI you a eliminate significant restriction on the intake track. thats were most of the gains are along with more precise fuel metering. Be it itb carbs, efi with log manifold or itb efi, the peak gains will be similar its just that drivablity, torque curve and character may differ itb tuning at low engine speeds are more difficult compared to a log type tuned manifold especially with hot cams which is why you kinda wanted itbs in the first place right? with these late type variable manifolds (that steve have posted) adapted to the top of itbs, you can improve running issues at low speed and thickin up low end torque curve. |
Having manifold on top of ITB's does not change the tricky nature of tuning the ITB's at all.
It does open up the possibility of using a MAF sensor, though. |
| All times are GMT -8. The time now is 09:50 AM. |
