Mr Sydney - great looking engine and that's pretty much what I'm going for. Can you confirm what sits inside the interconnecting pipe work, is that where the resonance flap is? Is the filter t piece 'hollow' ?
Yep, resonance flap. The kit was supplied by Rothsport and controlled by Motec. Build thread here http://forums.pelicanparts.com/porsche-964-993-technical-forum/822904-carrera-rs-4-build.html |
throttle body setup and Motec programming. Just staggering performance across the rev range. |
http://forums.pelicanparts.com/support/smileys/grin.gif |
The principle is to make things simpler and create less restriction in the intake not more :) |
Would love to see a dyno plot? |
You don't want to use a MAF sensor on an ITB set up. I use a MAP (Manifold Air Pressure), TPS (Throttle Positoin Sensor) and rpm which combined is known as Load Sensing and @xn, corrected for temperature and altitude. Works very well!
I talked to Jeff about this just the other day. In my future.
Is it just me, or is this thread generating more interest than the 'chest' thread used to generate?
Bill K |
The thread turned out better than I thought, but I could use more info on some of these set ups. I'd love to try to work some of this out in the garage at home without having to buy into someone else's kit, but that might be wishful thinking.
-Steve |
With ITB's throttle angle is the most precise and fastest engine air requirement parameter. But since density changes with temperature and humidity it needs some compensation.
Factories use MAF because it compensates for small VE changes over engine life due to wear, use of different components etc. For example when BMW M3 (E46) MAF sensor fails, ECU goes to Alpha-N mode. And M3 CSL (E46) uses Alpha-N from the factory, if it would be so bad they wouldn't have went that route :) |
regards, al |
I have decided to go the tried and true route of Triumph 955i ITBs and a MS2 control unit (or AEM Infinity, depending on garage clean out success).
I have sourced out manifolds but linkage may be an issue. I'm thinking of making my own motorcycle style cables to connect with the stock SC throttle, but I'd love to hear some of your thoughts on this guys. I know there is at least one company on the web offering a modified weber style linkage, but at $500 its a bit pricey for what you actually get. |
http://forums.pelicanparts.com/uploa...1475477090.jpg
TWM bodies with a DTA S80 pro ECU, soon to have Fly by wire add on using a Jenvey throttle motor. Originally I was going to use an old bmw 3.0 DME to run this but decided the extra features the DTA has would be useful in future. The car screams all the to 7200rpm. |
The Singer uses some type of plenum with ITBs. Anyone know anything about it? Other than the fact that it looks awesome? Looks similar to Jeff Gamroths. This motor was built by Ed Pink.
If I remember correctly they use the AEM ECU. http://forums.pelicanparts.com/uploa...1475496132.jpg |
^ I'd definitely use MAF for road use over Alpha-N if my ECU was set up for it...I guess if it used for race then it wouldn't matter.
Anyone have any good base maps floating around they want to share?
I will be using Triumph Speed Triple ITBs with stock high impedance injectors , Weber-Style manifolds, SSIs and a free flowing exhaust. I'm thinking at this point of going with MS2 or SDS. AEM Infinity seems OK, but haven't seen it used on 911 with posted results. PM me? - Steve |
itbs
Both Megasquirt and AEM work equally well.....here are some relavent examples using various t'bodies...including Speed triples (x-faktory kits in this case). PMO ITBs with AEM Infinity https://www.youtube.com/watch?v=Aev44jCKzvo TWM/Borla ITBS with Megasquirt https://www.youtube.com/watch?v=4YTl6b25_kc https://www.youtube.com/watch?v=Wdj_gGKfsdU X-faktory ITBs with Megasquirt https://www.youtube.com/watch?v=d8rG1RIVxzY&feature=plcp https://www.youtube.com/watch?v=B0N0ayYOui8 https://www.youtube.com/watch?v=88_JJDFqAsk X-faktory ITBs with AEM Infinity https://www.youtube.com/watch?v=8hMuR3DUArM |
Singer Vehicle Design | Restored. Reimagined. Reborn |
Zurlinden
Regarding the airbox......you might contact Marc Zurlinden at ZurlindenLLC. Marc builds some fantastic 911s and my understanding is that he may have had several of theses beautiful airbox/filters made.
Zurlinden, LLC http://forums.pelicanparts.com/uploa...1476631833.jpg regards, al |
Thanks, Al and Peter.
Al, I'm going to be reaching out to you at some point in the future. I have been toying with some ideas for a while but I've been too busy with other stuff to actually do much of anything else. |
My al lkosmal inspired Triumph setup with Rasant AEM
https://c5.staticflickr.com/6/5670/3...c6f0bfa9_c.jpg https://c7.staticflickr.com/6/5763/3...226ac58d_c.jpg Now with PMO Weber K&N rainhats http://i35.photobucket.com/albums/d1...psj3wwpghl.jpg |
Thanks |
....... He's receiving my car in January to commence a rebuild, unsure as yet if we're going with ITBs or just sticking with current 98mm p/c and adding gt3 crank and rods |
Nice! Not nice with the current CAD exchange tho haha!
Merry x-mas....................from the x-faktory regards, al |
Forgot to add, they're made by AT Power here in the U.K. https://www.atpower.com |
Yes the exchange sucks. Lol.
That is Marc Zurlinden's 911....Smyrna Green. Marc builds some of the best , custom 911s on the planet. I had the opportunity to work on one of his projects and I was very impressed with the workmanship and attention to detail. regards, al |
The few versions I ran...
Rain Shield http://forums.pelicanparts.com/uploa...1372124362.jpg Race Top http://forums.pelicanparts.com/uploa...1389560929.jpg Flat Top Filter on Flute http://forums.pelicanparts.com/uploa...1395525938.jpg Half Tea Ball Filter on Flute http://forums.pelicanparts.com/uploa...1399510787.jpg[/QUOTE] |
Recently installed and tuning underway. X-Faktory and Rasant kits.
https://uploads.tapatalk-cdn.com/201...56f2cbb181.jpg Sent from my iPad using Tapatalk |
Early Andial 962 itb's rebuilt by Matt Blast
http://forums.pelicanparts.com/uploa...1487443340.jpg at 1 bar http://forums.pelicanparts.com/uploa...1487442962.jpg |
| All times are GMT -8. The time now is 09:50 AM. |
