here is my 964http://forums.pelicanparts.com/uploa...1673125240.JPG
1969 911T
3.4 liters Rasant throttle bodies, crank and cam sensor Modified 964 intake Motec M84 http://forums.pelicanparts.com/uploa...1673193149.jpg |
Side question: I have the complete carburetors (40IDTP.3C), throttle linkage, air filter box, etc. system from a 1969 911. I have listed it for sale in the local PCA region, to clear it out of my garage. I have CIS on my 3.2 engine in a 1973 911T, which I like, but sometimes I wonder about installing an ITB FI system. Would there be a good reason to keep the air filter box from the 1969 carb setup for future ITB system? Or should I just sell the whole carb setup complete and buy what I need if/when I go to ITBs?
You could sell the whole setup and just buy what you need at the time if you ever go to itb’s. |
https://uploads.tapatalk-cdn.com/202...b9d1aee202.jpg
RHD ITBs running Megasquirt. Otherwise stock engine for now (Melissa/M1 cams to come…?) Plenty of custom fabricated/modified bits and pieces. |
Where did you get the fan shroud? |
Where is everyone running their O2 sensor into the engine compartment? I have a ‘79 with no prev O2. Through the engine tin? Thanks! Gratuitious pic of my almost ready to install engine. http://forums.pelicanparts.com/uploa...1674781828.jpg
Doug,
I ran my O2 alongside the left hand heater hose by undoing the hose and feeding either end through the hole and then it’s just the wire thickness alongside the hose. |
What is everyone using for cylinder head temperature sensors and mounts.
I’ve seen the one on Turbokraft but it’s very expensive. Any other alternatives? Thanks |
Check out Chris’ Low Budget Dream Car Build thread; he fabricated one fairly easily (I think it was last winter or spring) and thus far it’s proven to be quite effective.
Just got my car back from Erik at Sport Purpose Garage who installed and tuned my Clewett ITBs with Masters ECU. 160 WHP but way, way better road manners and torque, especially at partial throttle. Super super happy with how this turned out versus my old Webers.
If you're looking for someone to install and tune one of these setups, I'd highly recommend him. Super communicative, works very fast, and does fantastic, clean work. http://forums.pelicanparts.com/uploa...1674913921.jpg |
That's a very clean setup.
Sent from my Pixel 7 using Tapatalk |
There is a lot of beautiful eye candy on this thread!
Here is my POLO 4 banger built in 2011. It has 23,000 miles on it now. The latest ones being built by tuners like Jerry Woods and others are now getting 230 to 250 hp. See the second set of numbers. The upper graph is of an engine speced close to mine. Mine has had head work done to my 993 heads with titanium valves and the dynoed engine has stock 993 heads. Dean guessed this engine makes maybe another 10 to 15 hp. I've tried to keep a period look in my 67. Here is a newer vintage look product from Jenvey. https://store.jenvey.co.uk/heritage/heritage-ida-pair-throttle-bodyhttp://forums.pelicanparts.com/uploa...1674922099.JPG http://forums.pelicanparts.com/uploa...1674922099.jpg http://forums.pelicanparts.com/uploa...1674922099.jpg http://forums.pelicanparts.com/uploa...1674922099.jpg http://forums.pelicanparts.com/uploa...1674922099.jpg |
Lost for words, that is absolutely beautiful.
Never get tired of seeing pictures of your engine. What displacement is your engine, and the 249 HP engine in the second graph?
| All times are GMT -8. The time now is 01:33 AM. |
