gptom's Avatar
72 915 input shaft seal
I have looked through many threads looking for the method of replacing the seal from the outside; w/o dissembly of the tranny
68 Beetle 68 to 72 sold
72 911T Nov 71 to present P/U @ factory Nov 19. Car was gift to myself for surviving the army
67 VW split window 74 to 76 sold
81 VW caddy 81 to present
Old 08-22-2016, 10:53 AM
tobluforu's Avatar
Ah yes, the wonderful engineering in regards to the 72. You got it right, that's pretty much the only way. I'm guessing it's leaking and spraying all over the clutch assembly? Some have drilled holes and created what is referred to as a dam, as is damn it this sucks.
Old 08-22-2016, 11:08 AM
E Sully's Avatar
Some reading.
Input shaft seal Problem with 915 Mag case
Ed
1973.5 T
Old 08-22-2016, 02:41 PM
If your 915 box is a 72 you can only do it from the inside and the whole box has to come apart!
Old 08-22-2016, 03:36 PM
kwikt 911's Avatar
Yes... did it a few times before going with the 'Dam seal' trick. The 72 trannys definitely suck!!
Old 08-22-2016, 05:10 PM
Under the radar
Trackrash's Avatar
It is possible to have your transmission case "upgraded" to the newer style removable release bearing tube. There are a couple of places that offer that service.
Gordon
'71 911 Coupe 3,0L outlawed
Old 08-23-2016, 08:43 AM
