87 Carerra, 3.2 liter en
Can't Find Ground
I have a 1987 Carrera. I have done a lot of research on this forum in trying to locate my ground points throughout the car. Several of the forum members spoke to a ground point behind the battery. For instance one member wrote: My 87 has 1 ground coming from neg. side of battery to the front fender. Pull the battery and its right there. Ground from battery might be 8 inches long. When I checked the ground, ohms, on injector connection, my meter was around 14k ohms."
I have pulled my battery and there is no ground point or wire. I have checked for this over and over. Can someone please direct me as I need to find all ground points to deal with a no-start issue
Also, does anyone have a picture of the various ground points. I have the diagram that shows the ground points it is simply an illustration and not a photo of the different grounds. I am not mechanically inclined and so I really need to be able to see what the ground points actually look like so I can check them
Thanks so much
Old 09-11-2016, 11:22 AM
non-whiner
mreid's Avatar
Follow the negative (-) battery cable. What is it connected to?
"Too much is just enough."
Old 09-11-2016, 11:35 AM
Chain fence eating turbo
My 87 has a ground to the inner fender, not the fender itself. If you can't locate where it terminates, it must have been modified AFAIK??
Old 09-11-2016, 12:11 PM
Use common sense......
Follow the above suggestion or post a picture of your battery. Could you crank the starter?
Tony
Old 09-11-2016, 12:21 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Thanks so much
Hope this helps.
Best,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 09-11-2016, 02:15 PM
My Odyssey PC925 install
Follow the ground cable, see last 2 pictures. Look under the mess of cables and windshield washers hoses.
1988 Carrera coupe
1966 250 Ducati
2015 VW Golf TDI gone because Dieselgate!
2021 VW Golf TSI
2014 Ninja 300
Old 09-11-2016, 02:22 PM
non-whiner
mreid's Avatar
Dude, that is your ground post.
Old 09-11-2016, 02:49 PM
BFT3.2's Avatar
______________
'88 911 Coupe
'98 Spec Boxster
'85 380SL Benz -Euro
Old 09-11-2016, 03:19 PM
M4reid & BFT3, as well as everyone else:
Thanks so much. I got it now---Like Duh!
Sorry for the crazy, stupid question---but like i said, I got it now
Old 09-11-2016, 04:34 PM
Since we are on the subject of grounds, anyone know what/where points #13 (XIII) and #14 (XIV) are? Are they part of the taillights? I ask because I have an intermittent turnsignal indicator "weirdness".
Weirdness = Several times now, at night, with the lights on, my turnsignal indicators have been sort of illuminated all the time. They still flashed when I used the turnsignals (not sure of the turn signal lights them selves though). Last time, I drove 3 miles with this problem, stopped for gas, when I started the car again problem gone. My first step to try and address this problem is check all the ground points and fuse/fuse contact points. Car is a stock 1976 911S.
Who, What, When, Where, Why and How.
Old 09-11-2016, 09:27 PM
RETIRED
Joe Bob's Avatar
I had a brother in law so stupid he couldn't find the ground, either.....
2012 ML350 3.0 Turbo Diesel
Old 09-11-2016, 09:57 PM
