Steve F's Avatar
Question Thermo-Switch & Throttle switch questions
1981 SC ....I measured 24 ohm's 1 side to ground, 0 on the other and 24 ohm's across, does it matter which side the wires go to, I don't understand the Bentley schematic, Also same question for the throttle switch. Confirmed it goes off and on, but not clear on the brown/ green wires, which side goes where. I don't think this one matters but I'll ask anyways.
Thanks much,Steve
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate
1967 912-1985 Toyota FJ60 Landcrusier
1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4
1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag
1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS
Old 08-31-2016, 05:16 AM
T77911S's Avatar
yes it does matter.
I think the terminal on the TTS are sized so the wires fit accordingly.
one wire is the actual ground for the CSV. that goes to the 0 ohm terminal.
the other wire is a power wire to the heat the TTS to limit the amount of time the CSV can run.
brn goes to the common terminal on the TS.
according to the drawing gr goes to terminal 2 and bl goes to 3.
don't know for sure but 2 may be closed at idle.
it does matter one wire is looking for ground at idle, the other at WOT.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 08-31-2016, 06:10 AM
Steve F's Avatar
Thank you T77911S, can you clarify the TS please, if I'm looking at the switch from the fan, which side gets the brown wire, driver side and the brown to the other side? I will check out the TTS and see if the terminals are same size, that would make it a lot easier
Cheers,Steve
Old 08-31-2016, 06:37 AM
ROW '78 911 Targa
timmy2's Avatar
TTS has yellow on small terminal, red/black on larger terminal.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 08-31-2016, 08:37 AM
Steve F's Avatar
Thank you gentlemen, The TTS is as you say, different sizes,.. idiot proof Now on the TS, I only have 2 wires, brown and green. I finally noticed that there are numbers on the top of the switch and I had reversed them, I now have the brown on terminal 2 (driver side). What would this have caused or hindered? Haven't started it yet, still at a partial engine drop stage.
Thanks again
Old 09-01-2016, 05:29 AM
