Kool-aid-82's Avatar
Parts?
Originally Posted by dap930 View Post
I hope this not your problem, but there is a disk in the transmission with 8 magnets on it. If one or more of these magnets come loose (hopefully goes to the bottom of the transmission) then the speedometer will not read correctly. The speedometer is looking for 8 pulses per tire revolution. Disconnect the puck sensor wires in the tunnel and check with VOM to see if you get 8 pulses per tire revolution with the back of the car jacked up. If there are less than 8 pulses then the magnet carrier inside the transmission is the problem. It can be accessed by removing the transmission side plate. With fewer than 8 pulses the odometer will still read, but not accurately.
Where do you get the replacement part/wheel?
And how hard is it to replace?
Billy,
MoosgrunMetallic - 81 911 SC - (Carbon fiber Wrap)
Drank the Koolaid in 82
Old 09-01-2016, 07:08 PM
Dial 911
A horse with no name's Avatar
Hi...As mentioned, just use a multi-meter with it set to 'continuity' to check the magnets...You can use either lead on the multi-meter. Each pulse will produce a 'beep'.
PS - Billy, its the puck that is posted in the photo. It's on the side of the transmission and is very easy to replace - One bolt holds it on. It unplugs from the speedo wiring harness which is located under the tin plate on your back seat floor board- 4 screws.
Our host stocks them.
For SC's Electronic Speedometer Sending Unit
Part #: 911-606-209-00-M100
For 911(1985-86) Speedometer Sending Unit, 911 Turbo (1985-88)
Part #: 911-606-209-01-OEM
Cheers!
“Simplicity is the ultimate sophistication.”
Leonardo Da Vinci
Old 09-01-2016, 09:48 PM
The magnet speedo plate is easily found used. I had one and could not sell it so I threw it out. Getting to it is somewhat of a chore but doable with the gearbox inside the car.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 09-02-2016, 06:16 AM
Reads up to 55 mph max now but going much faster than 55.
Old 09-20-2016, 09:56 AM
when you are going 20, does it read 20? How about at 40?
You're sure the odometer is correct?
Old 09-20-2016, 10:18 AM
Kool-Aid,
Check out Uwon's post in the 911 Engine building forum where he removed the magnet carrier from the transmission. He found all the magnets in place, so he has some sort of problem with puck (sensor), which is nothing more than a reed switch whose contacts "make" when in presence of a magnetic field.
-Dennis
1977 930 Slant, MS3 EFI, Carrera intake, Twin plug, Powerhaus headers, Magnaflow muffler, Garretson intercooler, GTX3071R
Old 09-20-2016, 11:54 AM
counting 8 pulses per revolution sure would answer a lot of questions.
Rick
88 Cab
Old 09-24-2016, 07:29 AM
