G50911's Avatar
help decoding my engine #6292249
i have a project car that has the engine # 6292249 and i'm having trouble figuring out if it had weber carbs or mechanical injection. from what i found it's from a 1969 911E (i think).
can anyone help confirm?
1967 911 (Azzuro Thetys) - #308439
1971 911 (PTS Black) - Built 3.6 Sleeper
1989 911 (Grand Prix White) - Cabriolet Bone Stock
Old 09-05-2016, 07:42 PM
War Vet
matt930s's Avatar
E's were injected.
MattR
Dr. Phatt
Old 09-05-2016, 08:50 PM
G50911's Avatar
thanks matt. can you or anyone confirm the engine is in fact from a 69 E?
Old 09-06-2016, 07:26 AM
Originally Posted by matt930s View Post
E's were injected.
MattR
Yes^^.
However, number 629XXXX can also refer to a 79 SC engine. Check the engine number. A 69 will have a 901/xx number and a 79 will have a 930/xx number.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 09-06-2016, 07:32 AM
G50911's Avatar
how can i confirm this?
Old 09-06-2016, 07:35 AM
If you're referring to my post, you can confirm your engine number by simply reading it--located on the flat portion of the case, just to the right of the vertical stamping for the serial number.
In the pic below, the green arrow points to the location of the serial number, and the red arrow points to the location of the engine type number.
If you want to confirm the possibility that the 629xxx could be a 69 or 79, you can reference this site:
Fahrzeug-Identifizierung
L.J.
Old 09-06-2016, 08:00 AM
G50911's Avatar
thats perfect ossiblue, thanks!
Old 09-06-2016, 08:08 AM
