Understanding my transaxle. Help.
88 Carrera. 3.2. G50. On the way to work this morning and the driver side axle completely detaches from the transmission. Slaps around for a second before I can get stopped. Had the car towed home and got it lifted. Looks like all six bolts just backed out. I have one hole that the threads are slightly buggered up. The rest are fine. I can handle that fix but something that has me curious is that while the passenger side is still intact, I have no power going to that wheel at all. It just seems to me that the missing axle should be just like that side slipping and I should have power to the other side. Am I missing something? Thanks
Cordell. 88 Carrera sunroof. |
Uh no, there's a differential in there. Allows the two sides to rotate att different speeds. Needed because in an arc, the outside tires on a car travel further than the insides.
So while the left side is stationary, the right side rotates twice as fast and vice versa.
Matt - 84 Carrera |
Member 911 Anonymous
Yes, you do not have Limited Slip Differential.
The Drive-side is the one that the "power" Very important that you re-torque after couple of hundred miles and do it again after 500 miles. ( do 10% over spec ) BTW, I bet you heard some clicking before the failure, yes? Unless you have very loud exhaust it is very slight and only when you take off.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 10-19-2016 at 07:05 AM.. |
Thanks guys. I feel better now. Not sure about the clicking with the radio on but I did get a hell of a vibration right before it came loose. I was running 80 and was able to get slowed down a bit before it did.....
Check everything for damage, like the chassis, accelerator rods etc, take your time and a bright light.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
make sure the bolts are clean and the proper length when you fix it. also NEW washers.
check the other side. you should see 2-3 threads sticking out past the flange, if not the bolts are too short. you can get new bolts and washers at Fastenal. they come in a bag of 50 if you need to replace more than the 6. proper torque
I get new bolts, by the way. Loctite it in.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Very strange that your CV connection came undone. The G50 uses the larger 108mm
flange and uses 10mm bolts. The 10mm bolts rarely to never come loose as opposed to the 8mm bolts used on the '78-'84 100mm axle flanges. Strange indeed! Perhaps someone had the flanges off previously and didn't torque them correctly to 60ft lbs. The 8mm bolts only call for 30ft lbs torque.
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa Last edited by uwanna; 10-19-2016 at 04:31 PM.. |
