Detached Member
NEED AFTER MARKET A/c FAN BELT HELP
its some sort of aftermarket A/C system the belt broke and I've never had to deal with it before. PP does not have a listing. It measures 10 mm wide and 1,000 mm long as near as I can tell, ribbed on the outside and smooth on the running side. Should I just go to NAPA and see what they can hook me up with? And the A/C sort of works to boot!
Hugh |
I would try a local part store. Take the old belt in. Sometimes there is text on the belt that has a size. They should be able to measure the old one. Hopefully the belt adjustment is as easy as the stock system.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Member 911 Anonymous
just go to the FLAPS and get a the DAYCO 3 year warranted belt. works just fine.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Detached Member
Thx, I'll do that tomorrow.
Hugh |
Usually for an SC you use a belt PN 900-192-027-50 which was the standard AC belt for a York. Pelican sells the belt Here , and if you get stuck on the road it would be a 13x1100 ; 13 is the width and 1100 is the length.
Appears you have an aftermarket Seiko-Seiki rotary vane compressor, two groove. In most cases a 13x1100 will work; if you have an issue it would likely be on the 1100 length if any.
Kuehl 1987 911 cab, modified https://griffiths.com/ |
Administrator
Good info posted above. If you run into an issue like this again and can't seem to find what would work in our parts catalog please do not hesitate to contact one of our P car specialists here: Pelican Parts - Contact Us
Thread Tools | |
Rate This Thread | |
