Selfish headlight upgrade request
OUCH!!! My head hurts!
I just spent the past hour reading up on headlight upgrade and I'm even more confused now than before, so I'm making a very selfish request and I'm asking for someone...anyone...to put it in simple terms: How can I upgrade the headlights on my 68 912 so they are better than a 1950's flashlight? I am not concerned with them being "original or model correct", as long as they look remotely like they are from the same period. They can be sealed beam or bulbs style, doesn't matter. I don't want to spend $1000. I know I'll need relays for any upgrade. I'm hoping for a pretty simple list of parts that I can buy and put together with my existing lights, which are basically stock. I know it's kind of a DB move to ask, but I'm really lost on this one. Thanks
1983 SC - sold 2002 996 C4S - sold 1968 912 |
I am assuming you currently have DOT sealed beams. If so, the easiest way to upgrade is to get a set of Hella E Code 7" H4's (they may be labeled for off road only). They come with standard bulbs and you just replace the sealed beams with these. Since the wattage of the bee bulbs is the same as the sealed beams, you do not HAVE to install relays but it is prudent.
I did this on my cars and the stock wattage in the E code lights is a substantial improvement.
Agreed. I have the Hella H4 bulb (purchased from Pelican of course) in my 912 and I did add headlight relays.
Easy.
-Dave in Minnesota 96 C4 Cab, 85.5 944 82 SC Targa SCWDP #0023 82 928 67 912 60 T-5 B Cabrio |
I agree with HarryD's recommendation if cost is a serious object. Get these:
7" H4 Headlamp - PelicanParts.com and these: 3800 Lumen H4 LED Headlight bulb Given how little the above LEDs draw, a relay is less important, but I'd still do it. Early 911 Headlight Relay Kit (65-73) - JWest Engineering I think it's also worth spending a bit more and getting rid of the sugar scoops and getting the Bosch H4s. http://www.pelicanparts.com/catalog/SuperCat/0810/POR_0810_ELLITE_pg5.htm#item15
1986 911 Carrera Coupe 2016 VW Golf R 2008 Toyota Highlander (given to kid) 2021 Kia Telluride 2020 BMW R1250RS Last edited by PabloX; 10-22-2016 at 04:54 PM.. |
Start with the basic Hella H-4. See how you like it. If you need more, then move to higher wattages or LED's.
I have never felt the need to go beyond the stock wattage. The pattern of an E Code H-4 is significantly different than a DOT Lamp.
Member 911 Anonymous
Well to go Euro H4's with Relay and maybe LED kit you will spend $700-800 ( without trim ring )
Here is mine: ![]() ![]()
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Juergen
'86 Carrera Cabriolet Grand Prix White '09 VW Beetle Convertible ‘24 Audi Q8 etron |
go for an H4 LED setup from eBay. $40-$70 per pair.
I have a set in my 1973 and they are great.
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
Sirius Gen 7:
https://www.siriusledlights.com/collections/h4-9003-led/products/7g-led-headlight-h4 I tried the eBay, and they were worse than the stock bulbs. Remember 1 Watt = 100 Lumens as a rule.
This seems to be a real personal preference subject, two posts in and we've already deviated to LED
![]() Sealed beam H4s and relays it is. Thank you, gents. Thank you Pablo, for the links.
I went this route to replace my 964's H5's, after reading PabloX's and similar posts on this subject, except I opted to skip the relays, which I think are unnecessary with the low power demands of LEDs. So: OEM H4's + Cyclops LEDS. If/when the Cyclops fail, I will get the SiriusLED H4's which I was unaware of when I bought my setup. VERY happy with the OEM appearance of the lights and the light output. It's a massive upgrade in lighting performance compared to the anemic H5's with crusty lenses. |
abides.
Install some clear film on the new lenses so you don't wind up with pitted glass like you see in draco's photo.
Not installing a relay kit on a car with 48 year old wiring seems a bit silly to me.
Graham 1984 Carrera Targa |
I drive a night often as well.... I tried many things over the years. I want all the light I can get. The new LEDs are the way to go IMHO. Low amperage, plenty of light. Very long life. No downsides to me
1986 911 Carrera Coupe 2016 VW Golf R 2008 Toyota Highlander (given to kid) 2021 Kia Telluride 2020 BMW R1250RS |
The Hella E code is a true H4 headlight, and a great bargain. They come with H4 bulbs that you can upgrade to LED at any time. Even stock they are a tremendous improvement over a conventional sealed beam bulb, or even an upgrade sealed beam.
They are the real deal. |
did the relays and h4''s
i changed out the sealed beams about 4 years ago to the H4's. I installed 4 porsche round relays and had a relay feed each light and beam separately. a great upgrade.
with the separate relays you need not worry about any size bulb. Some people use a 100 watt high beam bulb draws 9 amps x 2 = 18 amp and that is a lot to run through the light switch contacts. a 60 watt low draws 5 amps x 2 = 10 amps and that is a lot to feed through the light switch. Definately do it.
1975 911S Targa Silver Anniversary Edition |
^^^+ true but you will need to upgrade to ceramic connectors for higher wattage bulbs.
OK, I have sealed beam H4s, relays and new seals & gaskets coming.
I took the buckets out today and what I have is, in order of front to back, trim ring, lens (fluted BOSCH), mount (the piece the adjusting screws connect to), retaining clips. reflector & bulb. Is that all I need? Does the sealed beam just snug up to the mount? And since both the sealed beam AND the existing lens are fluted isn't that just gonna spray light all over the place? Do I now need a clear lens instead of the fluted one I currently have?
do your current headlights look like this http://forums.pelicanparts.com/uploads23/Sugar+scoop+single+screw+mount1405749421.jpg
or this http://www.pelicanparts.com/techarticles/101_Projects_Porsche_911/71-H4_Headlamp_Upgrade/images_med/Pic3.JPG Almost sounds like you're already running the latter (euro bosch h4s) -- on the former (sugar scoop assemblies), the sealed beam headlight assembly would remove as a single piece (lens, reflector and bulb -- which is permanently affixed to the reflector) and you'd replace that assembly with the sealed beam h4 you just picked up. On the latter, euro bosch h4, the bulb would fit into the reflector, which would also separate from the lens. |
Thanks darrin.
My set up is indeed like the second link you posted. My reflectors are kind trashed...pitted in some spots...that's why I was hoping to replace the set up. There are no relays installed either so I'm not quite sure how to proceed.
