Send a message via AIM to sempaipaul
What's the tool to remove these?
Item #4 and #17 ---- appears to be the same tool?
Paul
03' Audi RS6; 16' 328i xDrive Touring; 13' X3 mSport, 91' e30 M52
Old 11-13-2016, 03:48 PM
Home of the Whopper
If by same tool you mean big pipe wrench, then yes.
But there are special tools for both.
Search for ball joint nut. Plenty of opinions on removal.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 11-13-2016, 04:05 PM
There is a guy selling a nice looking version here:
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/916403-fs-911-front-ball-joint-nut-socket.html
1982 911 Targa, 3.0L ROW with Webers
Old 11-13-2016, 04:15 PM
I removed mine with an air chisel it did not damage the nut.
78 911 st backdate
87 944
00 996
Old 11-13-2016, 05:12 PM
michael lang's Avatar
#4 & #17 are not even close to one another. #4 is a wrench extension that loosens/tightens the big nut at the top of the strut tower that holds the insert in place. It's open in the middle so that is can slide over the strut insert. #17 is the ball joint and the socket that loosens/tightens the ball joints look like the top of a castle or the Rook piece in a chess set. The tools don't even look like one another.
Mike
'89 CARRERA
#402
Special tools for #4 and #17.............
Paul,
I have the steering ball going removal tool (#17) and probably the front strut insert gland tool (?) too. Could you post a close up picture of the front strut gland you are removing? The tools were used for my '78 SC suspension upgrade many years ago. I could mail them to you.
Tony
Old 11-13-2016, 05:19 PM
This is the tool you need to take the nut off at the top of the strut assembly, #4. Since I have not yet replaced the ballpoints in my car I have not had to buy that tool yet.
The link attached to this thread gives you an idea of the tool used for #17.
I hope the photo helps see the difference in the two tools.
Which parts are you trying to replace or are you going after both? I'm not that far from if need to use my strut tool.
Mike
'89 CARRERA
#402
Old 11-13-2016, 05:31 PM
The abovet tool is just for Bilstein retainers.
206 637 4071
Old 11-13-2016, 06:01 PM
RETIRED
Joe Bob's Avatar
Yep, pipe-wrench for me as well....
2012 ML350 3.0 Turbo Diesel
Old 11-13-2016, 06:05 PM
Originally Posted by boyt911sc View Post
Paul,
Tony
Tony,
Here is what the Boge gland looks like:
I would really prefer not to use a pipe wrenching able!
Paul
Old 11-15-2016, 04:36 AM
Big-ass channel-locks is what I use for Boges. No shame. Gotta get em off. You ain't gonna reuse that Boge cap anyway. You're going to put Bilsteins in if you're smart and use the above Bilstein tool, which of course doesn't come with the inserts and has to be had from Bilstein. They used to come with them.
206 637 4071
Old 11-15-2016, 04:48 AM
Registered Minimalist
75 911s's Avatar
To take off:
To put on:
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 11-15-2016, 06:06 AM
Using improvised tools.......
Originally Posted by sempaipaul View Post
Tony,
Paul
Paul,
There are several ways to do things. JW and Duane have given you good examples. I had Bilstein inserts in my '78 SC and this was what I used:
For the Bilstein insert removal, I used an old Bilstein gland and made a positive version to remove and install the gland with the help of a spanner.
Don't worry about using a big channel lock plier or a pipe wrench. Wrap some masking tape on the gland to minimize the abrasions if that is your concern or find the appropriate tool.
Tony
Old 11-15-2016, 07:28 AM
If you buy the Bilstiens and you don't get a tool, contact Bilstien. They will mail you the tool for the top nut for free. At least they did a few years back when I did my suspension refresh. The bottom nut is a different tool.
Old 11-15-2016, 08:28 AM
