Riggs (guest)
Guest
Posts: n/a
Change/upgrade "eyebrows"? around the headlights
Not so much a comment as a question: I'm looking at a classic F-series 911 and am seeing a lot of them in the US which have larger silver fittings "eyebrows"? around the headlights. Are these easily replaced with the more elegant and recessed fittings? Is this costly?
This post was auto-generated based upon a question asked on our tech article page here: Porsche 911 H4 Headlight Upgrade | 911 (1965-89) - 930 Turbo (1975-89) | Pelican Parts DIY Maintenance Article
Old 11-16-2016, 08:09 AM
Nick at Pelican Parts's Avatar
I am not 1005 sure. A kit may be available to make it easy. Give our parts specialists a call at 1-888-280-7799.
I opened a post in our forums. A Pelican community member may be able to answer your question.
- Nick
i presume you mean changing from the US sealed beam versions to the H1 or H4 set ups? yes its quite easy and i wouln't lose any sleep on it with regard buying a car or not! Focus on the engine, gearbox and how straight the chassis is, you'll have no problems with the lights
Old 11-16-2016, 01:12 PM
