49willard
Adding fuses to footwell blowers, where?
My 86 Cab (built 11/85) does not appear to be fused for the footwell blowers. Pulling # 2 fuse in the luggage compartment changes nothing. Pulling the fuse in the engine compartment removes power to both the engine blower and the footwell blowers ( the footwell blowers are depowered by depowering the relay?). Looking at the wiring diagrams at the back of the Bentley Manual shows shows the #2 fuse in the luggage compartment powering the footwell blowers via the Additional blower relay for 1984-1987.
The 1988-89 wiring diagram shows 10A fuses "downstream" of the additional blower relay, 87 terminal. Where is that relay and is that where others have added fuses? Picture?
Bill
1961 356B coupe-long gone!
1986 Grand Prix White Cabriolet
Old 11-20-2016, 09:07 AM
EMT/TechRescue Instructor
86911cab's Avatar
Place it on the white/green wire. On that side it will isolate the motor from power in the event of an overload. The brown wire it the ground.
1986 Iris blue 911 Cabriolet
2017 Ram 1500 Night edition
2025 BMW X-5
Old 11-20-2016, 10:53 AM
49willard
Thanks for the responses. I was hoping that there was a more accessible location that cutting into the blower motor leads in the footwells which was why I asked where the relay that powers the footwell blowers is located hoping that I could find a spade connection in the green/white wire. As an example the clean method of fusing the dash lights off the spade terminal on the light switch. Just looking for the cleanest way.
On a different note, I just finished removal of an old aftermarket alarm. I am not experiencing any gremlins from that effort!
Bill
Old 11-20-2016, 11:30 AM
Not sure if this is exactly what you are asking, but on my 88 the 10A fuses are inline and located in the footwells themselves. Plenty of room to tuck them in behind the cover panels.
Old 11-20-2016, 12:15 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
While you are in there.....
Have a look at my post "Added fuses and relays".
For the 3.2 model years and prior, fusing was not Porsche's finest hour.
Best,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 11-20-2016, 12:31 PM
49willard
I will do the same, not exactly the "elegant solution" on Porsche's part. Thanks for posting.
Bill
Old 11-20-2016, 01:01 PM
49willard
Best,
Gerry
Thanks Gerry,
I found your previous post on fuses and relays and am going down the same road.
Bill
Old 11-20-2016, 01:11 PM
86911cab's Avatar
When the wire comes off terminal 87, it is shown splitting off 3 ways from a weld joint. Putting it there would require cutting wires.
You could make an extension to the harness at the blower. I'm guessing the connectors at the blower are spades? Using separate insulated spade lugs and heat sharing the wires together. That is what I will probably do when I get a round tuit.
Old 11-20-2016, 05:14 PM
49willard
Do you happen to have a picture of how the fuses were added to the harness by Porsche? Did they just cut into the sheath containing the 2 wires and "splice in a fuseholder/fuse? I would like to add them to my 1986 as much as possible to the way that the factory did it. My 86 Cab is essentially stone stock and with exceptions like adding the fuses I intend to keep it very stock.
Bill
Old 11-21-2016, 05:16 PM
sugarwood's Avatar
In the photo, the fuse itself has been removed from the housing.
I can post a better photo tomorrow evening.
1986 Bosch Icon Wipers coupe.
Old 11-21-2016, 05:57 PM
49willard
Thanks for posting the photo, unless Porsche came up with a slicker addition of the fuses in 88 and 89 I will follow your example. I had considered using the 2.8mm male and female blade connectors by disconnecting at the 2 blade plug and installing the male/female blade connectors and the fuse between the factory connector and the motor. Possibly a be a bit over the top seeing that they will clearly be out of sight!
Thanks again
Bill
Bill
Old 11-22-2016, 03:27 PM
Connectors.
Thanks again
Bill
I used the blade connectors.
Gerry
1986 911 Targa.
Only in L.A.:
Old 11-22-2016, 03:56 PM
sugarwood's Avatar
My photo offered little detail of where the wires go.
Let me know if you want me to open it up and really take some details photos.
Old 11-23-2016, 09:58 AM
