Throttle response
Hi.. I have a 79 SC coupe.. my question is... what makes the throttle response so quick on these older 911s. its kinda quick like riding a motorcycle. just curious thank you very much.
sylvester
Old 11-22-2016, 02:36 AM
T77911S's Avatar
if it is CIS, the vacuum controlled WUR helps. its a fairly light car, manual trans which means a more solid link from engine to tranny, no smog crap.
CIS was not a great performance system by any means although it did come on very expensive cars
carbs have much better throttle response
JMO
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 11-22-2016, 04:58 AM
Chain fence eating turbo
I've never heard of a quick throttle responsed CIS?!
Old 11-22-2016, 05:46 AM
Recreational User
porschenut's Avatar
This is a joke, right? CIS has the worst throttle response of any 911 ever made. Even the EFI 3.2s have lousy response. Good response is only had with carbs or MFI on the longhood cars. Or carbs or ITBs if installed on a later car.
Old 11-22-2016, 07:52 AM
Eng-o-neer
Tremelune's Avatar
Independent throttle bodies.
Getting ITBs on a Porsche is usually done by stealing parts form larger motorcycle engines. Nobody has a plug-and-play kit for it, though it is being worked on:
The next big thing....3.0 EFI/ITB w/Rasant engine management
Old 11-22-2016, 09:37 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Have to agree 3.2 stock is really doggy but with properly timed 964 cams and SWChip, It makes a vast improvement.
+1 on SC, light ( lighter than 3.2 for sure ) car so it will be quick
'85 Carrera Targa
PCA/POC
Old 11-22-2016, 09:48 AM
Josh D's Avatar
Advancing the ignition timing on a CIS 911 definitely quickens the throttle response. It isn't all the CIS fault.
'80 RoW 911 SC non-sunroof coupe in Guards Red
It's not a Carrera.... It's a Super Carrera!
Old 11-22-2016, 11:05 AM
Bill Douglas's Avatar
It's a particuarlly good year for a 911SC, that may explaine the thottle response being excellent.
regards, Bill 1979 911SC
Old 11-22-2016, 11:06 AM
prschmn's Avatar
Could be this car has an Aluminum pressure plate-less rotating mass helps a lot. Any intake with the butterfly farther from the valve has inherently slower response-hence ITBs or carbs make a huge improvement. Increased ignition timing can help but at the risk of detonation.
Mark
www.exotechpower.com
1981 Targa-messed with. 91 C2 supercharged track rat
Radical Prosport-irritates the GT3 guys
40 years of rebuilding services
Old 11-23-2016, 04:41 AM
How does one know what the "correct" throttle response should be? I associate response RPMs/where in the power band the car is when accelerating (which I guess is just one variable).
Old 11-23-2016, 06:58 AM
Eng-o-neer
Tremelune's Avatar
It's not so much a correctness as it is that you want minimum latency between when the throttle moves and the engine is at the speed it will eventually reach for that throttle position. Well, I do. This is ignoring the downsides of lightweight flywheels etc, but...This is pretty close to ideal:
https://www.youtube.com/watch?v=XRXwWbo_mX0&t=59s
The only real value I'm aware of is during shifting, and most of these cars rev fast enough for the speed that you should be shifting at, so...
Old 11-23-2016, 07:14 AM
My CIS 911 3.0 has better response than my EFI 944...
911 has a lighter flywheel for sure, but the broad-brush maligning of CIS is incorrect in my opinion. Properly tuned it is quite good as the OP states.
Art
'75 911 US Carrera #390
'74 MGB, AH 3000 BN7 V8,
'65 Mustang Fastback, 66 bronco U13
Old 11-23-2016, 07:31 AM
