pete917's Avatar
What bits do I need for a 3.2 heat backdate
I want to do a heat backdate on a 3.2 Carrera.
I found this pic.
I need the left and right handside tin (the straight parts and the small squares with the holes in) Plus I need the left and right air ducts.
Does anyone have the partnumbers for these six items and will they bolt straight onto a 3.2 carrera.
For the left and right air ducts I need the left one to clear a 964 twin dizzy and the right to clear the sender unit
Many thanks fellas
Pete
Porsche, there is no substitute!
911 Coupe 1974 plus bits | Stuttgart eXchange | Channel P101tv
Old 11-29-2016, 09:49 AM
pete917's Avatar
Can anyone help?
Pete
Old 11-30-2016, 04:05 AM
So you're wanting to get rid of the extra blowers that are in the footwells and the engine compartment, or just the engine mounted blower?
Old 11-30-2016, 04:17 AM
Project Addicted
This is how I did it without buying any parts.
My 3.2 Heat Backdate Story
Jon
1966 912
1976 911 3.4 Backdate Project
1986 944
Old 11-30-2016, 06:31 AM
sp_cs's Avatar
See here Pete: SSI/Header Engine tin
Shirish
1987 Carrera, Granite Green
Old 11-30-2016, 07:28 AM
pete917's Avatar
Thanks everybody
Pete
Old 11-30-2016, 09:45 AM
pete917's Avatar
I dont have blowers in the footwell. I have a '74 car with a 3.2 engine in it.
Pete
Old 11-30-2016, 09:46 AM
pete917,
There are a couple of ways you can do this. I have a crossoverpipe on my heater system so that I only had to work one side:
Old 11-30-2016, 09:51 AM
I also diverted all heat to the windscreen defrosters:
Old 11-30-2016, 09:57 AM
pete917's Avatar
Originally Posted by SpyderMike View Post
pete917,
Thanks. I have a 964 twin distributor. Would that duct be OK to clear it. If so do you have the part number for the air duct so I can look for it.
Pete
I used the Porsche duct P/N 930.106.321.02 on the distributor side. What diameter is your distributor cap with wires? Mine was a very tight fit and the duct had to be bent to clear the cam oil lines.
To go the dual sided route I found this list on another website a while ago:
Following is a list of parts, prices may be out of date now:
Left hot air duct, 930.106.321.02, list $148.20
4 plastic nuts, 999.591.592.40, list $.12 each
2 rubber plugs, 999.703.044.50, list $.77 each
Right hot air duct, 911.106.327.00, list $53.45
Right engine cover plate, 911.106.036.00, list $14.89
Right engine cover, 911.106.827.00, list $5.04
Right air duct support, 911.106.331.00, list $1.30
Old 11-30-2016, 10:17 AM
pete917's Avatar
Im not sure on my dizzy diameter. Im not hear my car so will measure it later and report back. The second dizzy covers the hole in the tinware where your pic shows the orange pipe going through. So I would have to go for the side tinware wit holes for the pass through.
Pete
Old 11-30-2016, 10:26 AM
