RDM RDM is offline
Coram Deo
RDM's Avatar
120 mA draw
All,
My battery went dead after about 10 days sitting in the garage. After getting the battery charged and taking it on a checkout run, I disconnected the negative battery terminal and connected my ammeter in between. I found 120 mA draw, which seems like a lot for an old-school car.
The wiring for the car is fairly unmolested but for a dash light fuse, modern stereo (now removed) and seat heaters.
I went to the fusebox and jostled fuses one at a time with no effect until the fourth from the back. When I pulled that one, current draw dropped to zero. The clock also stopped, and the glovebox light stopped working.
Based on what it operates, the wiring diagram says this is fuse 18 which doesn't seem to match either the fusebox cover or the counting of fuses from the front. (page 4, trace 42 here: http://www.pelicanparts.com/911/911_Parts/Electrical/911_electrical_78SC_USA.pdf)
I know that wiring diagrams isn't completely up-to-date for a 1980 car. For instance I believe the Jetronic unit under the passenger seat is also on this circuit.
Any known bad actors on this circuit? What should I look for?
Thanks.
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio •
Old 12-01-2016, 12:06 PM
I had a similar problem with battery going dead. Pulled the fuse like you did and the clock and glovebox light quit working. I was puzzled till I found I had left the sliding switch for the glovebox light in the ON position! Ergo when I opened the glovebox the light was on BUT when I closed the door the light stayed on and I didn't notice it.
Just did a DOH! and slapped my forehead when I found my "problem".
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 12-01-2016, 01:03 PM
theiceman's Avatar
excellent troubleshooting , I would say you are 9/10ths there.
that circuit powers interior lights as well as glove box light and luggage compartment light ,.
Are you sure you your luggage compartment light is goin out when you close it via the plunger switch ?
if you cant pin it down start popping light bulbs.
I bet you will have it figured out by tomorrow.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 12-01-2016, 01:43 PM
not sure it's applicable to your situation, but on my '86, my failed door switch (interior lights wouldn't come on when I opened my door) was the root cause of a VERY similar drain situation.
Turns out that on my car, the power windows remain energized (can be closed) after the car's shut off and before a door is opened. Since my door switch never "told" the relay that my door was open, my power windows remained active whenever my car was off and pulled a drain that would kill my battery after a week or so.
Easy to check -- can you operate your power windows with the key out and do your interior lights come on when you open the door?
Cleaning my door switch so it worked solved my problem
Old 12-01-2016, 04:02 PM
Fleabit peanut monkey
Bob Kontak's Avatar
SC did not have the kermit palzer window relay thingie. 84-ish for start.
1981 911SC Targa
Old 12-01-2016, 05:39 PM
Rescuer of old cars
Arne2's Avatar
'84 don't got it either, more's the pity. Must b an '85+ thing.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 12-01-2016, 05:44 PM
Bob Kontak's Avatar
For sure post SC. It's a multi syllable German doo-hickey relay that keeps the windows active until you pop the door open.
Perhaps "frammitz" valve?
(FWIW, all the silly names are from MAD magazine from the early 80's)
1981 911SC Targa
Old 12-01-2016, 05:50 PM
Bob Kontak's Avatar
120 MA is pretty wimpy in broad speak.
1981 911SC Targa
Old 12-01-2016, 05:55 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Current draw.
Originally Posted by RDM View Post
All,
Thanks.
I believe that 120 mils is very close to spec.
Check the glove box light switch.
Have a look at the specific gravity on each battery cell.
Good luck,
Gerry
pm me as needed.
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 12-01-2016, 06:48 PM
El Duderino
tirwin's Avatar
Anything greater than 30 mA is suspect. How fast your battery drains is a function of the draw and the Amp Hour rating of the battery. Temperature affects the time also.
Like someone said earlier, pull the bulbs on the interior lighting circuit one by one until you find the culprit.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 12-01-2016, 07:27 PM
RDM RDM is offline
Coram Deo
RDM's Avatar
For a 55 Ah Optima Yellow Top, at 120 mA the maximum theoretical life before being completely drained is 19 days. That seems awfully short. Siegel's electrical book (https://www.amazon.com/Mechanic-European-Automotive-Electrical-Systems/dp/0837617510) gives 50mA as the standard, but it's not specific to any particular car. Ima go with Tim on this one.
Weekend plans have just been made! We'll see what comes.
Dru
Old 12-02-2016, 04:01 AM
famoroso's Avatar
FWIW, I wired a rocker switch in line (no cutting wires PLEASE!!!) with the clock's ground. When I park the car the clock gets powered down (via cutting ground). When I go to drive ithe vehicle again in a day or a week, etc. the correct time gets set and I turn the clock back on.
I have yet to check what the clock's specific mA draw is, but will do so for shyts & grins at some point.
Old 12-02-2016, 07:05 AM
El Duderino
tirwin's Avatar
For a basis of comparison, when I eliminated the parasitic draw on my 83 the steady state draw went under 10mA (I think it went to 7mA) and I haven't had an issue with battery drain since.
My draw was coming from the front windshield heater wiring. I don't have a front windshield heater option and I never found the exact source -- I just disconnected that wire at the fuse panel.
On my '83 fuse 18 has a black wire that goes to the trunk light and a red wire that goes to the interior lights, glove box and OXS relay. If you don't have an O2 sensor then you don't have the OXS relay.
Old 12-02-2016, 07:18 AM
Bentley
According to the Bentley, 0-100 mils is normal.
But, as previously posted, disconnect the battery
for a few days, and reconnect.
Let's be certain you do not have a defective cell
in your battery.
Best,
Gerry
1986 911 Targa.
Only in L.A.:
Old 12-02-2016, 08:19 AM
El Duderino
tirwin's Avatar
I think the point is a draw may or may not be problem. If the car is a daily driver and you're driving it enough that it is constantly recharging, then it's not an issue. If you drive it once a week or every couple of weeks and it sits in an unheated garage and you use one of those little Miata batteries, it's a bigger deal.
Old 12-02-2016, 11:01 AM
My 85 does have that feature.
Old 12-02-2016, 11:28 AM
RDM RDM is offline
Coram Deo
RDM's Avatar
in your battery.
Best,
Gerry
What would battery disconnection and reconnection do? Would that affect the draw somehow?
Dru
Old 12-02-2016, 12:35 PM
RDM RDM is offline
Coram Deo
RDM's Avatar
Depends on the time of year. When it's not raining, snowing, or salty I drive it. This time of year where I live, it could be a month between drives.
The battery is an Optima Yellow Top, so not a Miata battery. I think there's a problem that I need to chase down.
Dru
Old 12-02-2016, 12:38 PM
RDM RDM is offline
Coram Deo
RDM's Avatar
I can't imagine that the clock would make this kind of draw.
Dru
Old 12-02-2016, 12:40 PM
Battery.
An internal cell discharge issue.
The idea is to check the battery voltage prior to
disconnecting, then leave the battery disconnected
for a few days.
Shorted or defective internal cells can reduce the voltage.
But look, just take your car to a Sears shop & they will
check your battery under load conditions.
G.
1986 911 Targa.
Only in L.A.:
Old 12-02-2016, 12:52 PM
