BobnJoz
Send a message via AIM to bobswei
'02 3.6 ticking sound
The car has been sitting for two weeks and it's cold here. I started it this morning and I hear a ticking sound from the lower right, valve, spark plug area. It sounds just like a lose valve adjustment (but not this engine year?) or lose spark plug. Speeds up with engine speed. I'm in a time crunch and just needed some ideas so I don't waste time.
Old 12-31-2016, 10:56 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Possibly loose exhaust/exhaust manifold/H.E.s too.
To confirm it is not tapping, use a long screw driver and put it to you ear and suspect area. HF stethescope would be better.
Go buy a cheapo cigar and blow smoke around the area look for air disturbance.
My 2 cents,
'85 Carrera Targa
PCA/POC
Old 12-31-2016, 11:15 AM
The Dude abides...
bigel's Avatar
How about posting a video with sound??
'03 Carrera 4S
Old 12-31-2016, 12:54 PM
Bill Verburg's Avatar
very likely a lifter that hasn't pumped up
this is often caused by
cold
sitting
heavier wt oil
old oil
lifter seals going or gone bad
if it's an '02 911 3.6 it wants 0w-40 M1
Bill Verburg
Old 12-31-2016, 01:08 PM
BobnJoz
I believe the problem is solved. I did the screw driver trick and could not pinpoint anything. It was near the front of the engine so I pulled the coil and plug and seamed OK. Put it back together and went for a short drive and I don't hear it anymore. I think Bill may have gotten it. A lifter that needed to get pumped up which maybe the reason I could not hear with the screw driver (it's deeper inside?).
Thanks for the responses. I sold the car and the guy will pick it up tomorrow and I want it to be perfect with no issues.
Old 12-31-2016, 01:26 PM
Chain fence eating turbo
Yeah, I've had sticking lifters in my old 996.
Give it an Italian tuneup.
Old 12-31-2016, 02:10 PM
