Harness help
How do you get these 40 year old plugs so snap back in?
Old 01-06-2017, 08:03 AM
911SC Tinkerer
merlinfe's Avatar
Vasoline or dielectric grease if you don't want to get yuk in the plugs. Horrible design.
-Steve
-'83 911SC Coupe
SSIs, Dansk GT3, EFI ITB, Instagram: @ Zinnmetallic_sc
Old 01-06-2017, 09:06 AM
dlagerstrom's Avatar
I like to use glycerin. Available at your local drug store. It has the added benefit of adding some flexibility back to the old rubber and it will evaporate completely over time.
-Dave in Minnesota
96 C4 Cab, 85.5 944
82 SC Targa SCWDP #0023
82 928
67 912 60 T-5 B Cabrio
Old 01-06-2017, 09:28 AM
ROW '78 911 Targa
timmy2's Avatar
Clean, lube, get it warm, press really hard and twist. Often a small dull flat blade is needed on the other side of the hole to get the lip to start going over the edge and start sealing in.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 01-06-2017, 09:34 AM
Thanks to all.
glycerine and heat ( hair dryer ) did the trick nice and easy .
Old 01-06-2017, 07:54 PM
ROW '78 911 Targa
timmy2's Avatar
A hot oil massage and a happy ending...!
Dennis
Old 01-06-2017, 09:00 PM
Yeah I used vasoline .
Old 01-06-2017, 10:43 PM
In my experience with rubber and silicone, petroleum (vasoline) should not be used on rubber/edpm or viton parts such as this example. As alternative I would use pure (food grade) silicone grease, or dupont christolube (tho, $$) which is good on dynamic seals. Making sure the lubricant is appropriate for the use environment (heat, etc).
I am sure others have alternatives, though 'Krytox' would not recommended for heat sensitive areas, if it burns it can be toxic.
Old 01-07-2017, 07:28 AM
