Stranger on the Internet
patkeefe's Avatar
EFI Conversion-need reference distance
Hi all,
I am into an EFI conversion on the SC. I am mounting the coils where the CDI/rear fusebox was. I need to build new plug wires, and I need the distance from that location to any point on the engine. I tried to approximate the distance, but I would prefer to have a better approximation. Engine is out of the car, on the test stand, which is what is making this difficult.
TIA
Pat
Patrick E. Keefe
78 SC
Old 02-05-2017, 06:48 AM
patkeefe's Avatar
Mount
Patrick E. Keefe
78 SC
Old 02-05-2017, 01:57 PM
rsscotty's Avatar
The location of your coil pack is going to make for a long length to get to the 4,5,6 bank. Have you considered mounting the coils in a central location like back by the breather cover area or on another mount off the engine above and on center. This would make a pretty even split for the plug wires and the components would mostly be hidden.
Old 02-05-2017, 02:32 PM
No need to build your own coilpack to plug wire set if you order these:
https://www.google.com/search?q=Autolite+96157+Spark+Plug+Wire+Set+for+93-00+Dodge+Chrysler+Plymouth+Eagle+3.5L&ie=utf-8&oe=utf-8
Usually they mount the coilpack at the back firewall.
Cheers,
Joe
Old 02-05-2017, 04:07 PM
7.0:1 > 11.3:1 > 7.0:1
Just last week I dropped 2.7 runners onto my 930 motor to see how to build fuel rails and a plenum. Happy to see I'm not the only one thinking about this arrangement.
Sorry Pat, no help on wire lengths
Old 02-05-2017, 08:02 PM
patkeefe's Avatar
Thanks anyway, guys. I have a fairly close approximation.
Jim2, I have the same SDS setup. I figured all along I would mount the coils where the CDI was, and the ECU in a box on the rear seat area. I had Ross make up the harnesses to those lengths, so I am sort of stuck with what I have.
Patrick E. Keefe
78 SC
Old 02-05-2017, 08:58 PM
proffighter's Avatar
Check my thread and ask if there are questions:
Another EFI conversion
Some things are updated here:
Another rust combat
Roland
930 Turbo '81 Too many modifications to list
Old 02-06-2017, 05:33 AM
