Weber Accelerator pump weak or no flow
Originally posted by mistake in Engine Rebuild Forum
I have a 3.0 with 40 IDA's that has sat for a couple of years. I have drained all the fuel put in fresh fuel. The car does run but is hard to start. I recently cleaned idle jets main jets and emulsion tubes. What I noticed is the accelerator injectors 2 out of the 6 have a good flow. 2 have no flow and 2 of them just dribble. This is when I am pumping the accelerator pump manually. I am not sure how to clean / clear this issue.
Vintage Owner
If it was sitting for a few years, I'd assume that the fuel has turned to jelly and the carbs should be completely disassembled, cleaned, and rebuilt. Paul Abbot @ Performance Oriented seems to be the Weber carb guru, but I understand that he's quite backed up with work. He does have some great information on his website that should be very helpful if you want to try to do the work yourself.
84 Targa (sold) 70 914-6 (sold) 73 914-6 2.7 conversion (sold) 75 GMC Motorhome (sold) 2016 Cayenne |
Looks like I can take off the accelerator pump and appears to be 3 passages I can spray with carb cleaner think I will try this before doing a full rebuild. The other jets I cleaned were not that bad and the fuel I drained of was yellow in color it was not that bad.
The membranes inside may be shot as well. Think Pegasus has them, not sure about our host but check. The float bowl control valves at the bottom of the float bowls could also be filled with crud. You will need to pull the carbs to get to these.
jhtaylor santa barbara 74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's. 73 Targa (gone but not forgotten) |
Jabb
Don't do this half ash with the ... not that bad comment. You will have more running trouble down the road. Just get 2 rebuild kits, disassemble, soak, clean, and reassemble. Check for air leaks on the main shaft.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
The float bowl valves in a 40IDA are already blanked unlike in a 40DCE so they allow maximum flow.
Your right the more I think about this the more I am leaning towards just getting the rebuild kits and going through the rebuild process also pull and clean the fuel tank.
Schleprock
Like Jack Stands said, do yourself a favor and check out Performance Oriented (Paul Abbott is member 1QuickS here on the forum) for an incredible resource of Weber technical information.
Kevin L '86 Carrera "Larry" |
When I service Webers I take special care to perform two tasks which result in even squirt from all squirters:
The valve in the screw that secures the squirter nozzle needs to be clean as well.
Paul Abbott Weber service specialist www.PerformanceOriented.com |
Once you do rebuild, try using non-ethanol (marine) gas frequently. Ethanol tends to pull moisture in which gums up your carbs. If your area is humid then it compounds the problem. When I lived in Hawaii I ran every other tank with marine gas.
Schleprock
Use marine Sta-Bil
