Formerly bb80sc
Vipergrün's Avatar
Post Okay to have timing set to 10 degrees BDTC rather than 5?
Hello all,
while tuning up my 80SC I found that the car seems to run better
set near 10 degrees BTDC, rather than 5 degrees. This is with the vaccum hose
connected and the O2 sensor disconnected, 900 RPM's. I do not appear to get any
detonation. I also to not seem to have a flat spot in lower RPMs any more.
Can I keep it like this? Anything else I should adjust to compensate?
I do not have a way to test the CO, but I did lean out the mixture until
it began to run a bit rough, then richened it up until it ran well.
Cross posted to Rennlist
cheers
-Brad
80SC
Old 10-22-2001, 04:25 PM
Post
if it doesn't ping, run it. you should be able to go 35° total advance safely, with good gas. with that much total, you would probably end up with about 10° at idle.
Old 10-22-2001, 07:03 PM
